Old 04-22-2009, 11:15 PM   #1
rebelman77
Radiator
Hi Folks I just purchased 66 C10 shortbed(283 Automatic Trans),I was wandering if there are any other year trucks I can rob a radiator from,like later models maybe.Any help or suggestions are appreciated
rebelman77 is offline   Reply With Quote
Old 04-23-2009, 12:09 AM   #2
Captainfab
60-66 Nut
Re: Radiator
Most later model trucks have crossflow radiators that are too wide to fit in the '60-'66 trucks. Some of the OEM radiators that can be adapted to fit are Impala's up thru '66 or '67, '67-'69 Camaro small radiator, '64-'67 Chevelle, '68 & '69 Chevelle small radiator, '62-'67 Nova, and '68-'72 Nova small radiator.
One of the more popular radiator swaps are the Summit Racing universal aluminum radiators. ChiefRocka did a writeup on his install here somewhere......I think there were one or two others as well.
Old 04-23-2009, 10:22 AM   #3
MikeN
MikeN's Avatar
Re: Radiator
Modine makes a new 3-row for our trucks with V8, and it's not too expensive.
MikeN is offline   Reply With Quote
Old 04-23-2009, 11:01 AM   #4
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: Radiator
Welcome to the Board.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 04-23-2009, 11:15 AM   #5
joe231
joe231's Avatar
Re: Radiator
CHEVY ONLY
Old 04-23-2009, 11:38 AM   #6
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: Radiator
* well, at least he realizes he has a problem.
Mac.
Old 04-24-2009, 07:15 PM   #7
rebelman77
Re: Radiator
thanks for the info-i'll be searching
Old 04-24-2009, 10:15 PM   #8
Daniel 61 Apache
Daniel 61 Apache's Avatar
Re: Radiator
I put in an aluminum radiator that I bought off of ebay. Just measured the size I needed and found one close enough to work. I can check the measurements and take some pics if you'd like. I made my own mounts by basically going to home depot and using some thick L brackets. Spent something like $160 for everything I think.
Project 61 build thread
Some people spend an entire lifetime wondering if they've made a difference....The Marines don't have that problem.
Sic vis pacem, para bellum. -- "If you want peace, prepare for war."
Daniel 61 Apache is offline   Reply With Quote
Old 04-24-2009, 11:39 PM   #9
rebelman77
Re: Radiator
thanks daniel a buddy of mine just made the same suggestion today about trying ebay thanks again
Old 04-25-2009, 02:49 AM   #10
LILRED66
LILRED66's Avatar
Re: Radiator
O'Reillys sells a "near-perfect" three core with auto tranny line connectors (minus the HARRISON embossed on the right side of the top tank) for around $200.00 and it works great with the bottom saddles and rubber cushions, as well as, the factory top radiator brackets & rubber cushions
LILRED66 is offline   Reply With Quote
Old 04-25-2009, 09:26 AM   #11
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Radiator
I got one from Summit. I went to a sheetmetal shop and had him bend a top mount for me. Looks like this.. Now I just have to refine it a bit so I can get some rubber under it to go between the radiator and the top mount.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-25-2009, 01:12 PM   #12
65fleet
65fleet's Avatar
Re: Radiator
hey man do you have a part number for that aluminum radiator from summit? thanks..
65fleet is offline   Reply With Quote
Old 04-25-2009, 07:03 PM   #13
Chevy Fleetside
Re: Radiator
I think it was this one http://store.summitracing.com/partde...5&autoview=sku but mine might be wider. I did remove the battery box and that made more room for me to put in a bigger radiator. If you don't need a tranny cooler they are even cheaper.
Old 04-25-2009, 07:05 PM   #14
Chevy Fleetside
Re: Radiator
I think mine is 27 3/4" wide though http://store.summitracing.com/partde...5&autoview=sku
Old 04-25-2009, 11:09 PM   #15
rebelman77
Re: Radiator
Hey thanks alot looks like a great fit nice and clean thanks so much very helpful .the pics are great thanks again
Old 04-26-2009, 02:02 PM   #16
Revin68
Recreational Grease Monkey
Revin68's Avatar
Re: Radiator
Im running a '91 chev PU crossflow in my '60 with a 305 auto. It has been in the truck since 1994 and the truck never overheats. I installed the 91 rad. shroud and a clutch fan from a '77 Malibu. Rock solid 195° or less.
Revin68 is offline   Reply With Quote
Old 04-26-2009, 08:21 PM   #17
rebelman77
Re: Radiator
thanks for the help fella's was in St. Louis today and found one that looks like its going to work fine, measurement are very close,out of a 64 impala he thought (20.00$).Great swap meet.Thanks for the help
Old 04-26-2009, 10:34 PM   #18
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Radiator
That's a clean install.
Alan's Classic is offline   Reply With Quote
Old 04-26-2009, 10:44 PM   #19
dedjr67
dedjr67's Avatar
Re: Radiator
I just got a new alum. rad from speedway 2 inches thick 26 inches wide for $140.00 but you will need a seperate trans cooler
dedjr67 is offline   Reply With Quote
Old 04-26-2009, 11:36 PM   #20
Revin68
Revin68's Avatar
Re: Radiator
I have found that a number of things from 62-64 Impalas fit well. Congrads on the score. =)
