BlahBlahBlah
Rear end swap
If I pull the rearend out of a 69 and swap in the rearend out of a 67 will all my brake lines and cables on the 69 just screw right in to the 67 rear without any modifications?
Member #1049
Re: Rear end swap
The brake cables are the same.. My brain is a bit foggy on the brake line fittings.. not sure if the 2WD 67 and 69 have the same little "tab" on the axle tube for the "T" fitting. why cant yours be a 4X4? then I would know the answer.. LOL
BlahBlahBlah
Re: Rear end swap
Well you know when I have a 4x4 question I just give you a call on the phone =)
Got part of the question answered, thanks
BlahBlahBlah
Re: Rear end swap
Bueler?
BlahBlahBlah
Re: Rear end swap
Looks like I may have stumped the band on this one.
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Rear end swap
To my knowledge there the same, If not you should be able to swap out any differences. The 70's up were wider and would make the steel lines different(longer) but I think the rubber line all hooked up on the pass side with 3/16 line and 3/8 nuts.
Re: Rear end swap
Should swap with no issues.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
Son of a gun
Re: Rear end swap
they will swap without modification. all of the changes happened in 71
Bill BEATERS ARE NEATER |
