Old 04-23-2009, 07:43 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
What front axle is this?
Sorry for my ignorance, I just started doing some work on my farm truck and noticed it has a different style front end than I'm normally used to seeing. It has a what I can only think to describe as a closed knuckle.
What type of axle is this, and what years did it come in?
sorry for the poor picture its really dark out today
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 04-23-2009, 08:14 PM   #2
muddobber
muddobber
Re: What front axle is this?
dana 44 i think they stopped using the closed knuckles in 70. i would lose the front lift blocks though cause they'e dangerous
muddobber is offline   Reply With Quote
Old 04-23-2009, 08:22 PM   #3
Wildstreak
Wildstreak's Avatar
Yea I know those things are about to be removed, its just a farm truck right now, bought it like that, they're tube channels not even blocks lol
57 chevy 4x4
68 burb 2wd:
Old 04-23-2009, 08:22 PM   #4
Wildstreak
Wildstreak's Avatar
Are parts for these harder to come by, if so should i just do an axle swap?
57 chevy 4x4
68 burb 2wd:
Old 04-23-2009, 08:31 PM   #5
onlyifihadachevy
from my understanding closed knuckle parts are harder to find because not many people use them.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 04-23-2009, 08:59 PM   #6
msgross
msgross's Avatar
It's a closed knuckle drum brake dana 44 like my 68 had. You can bolt in any dana 44 or corp 10 bolt from any 1/2 or 3/4 ton chevy...
Then you open up a can of worms with disc brake conversion (prop valve, MC etc..) to include power steering swap but it would be worth it. Find a newer 71 and up chevy and take all the parts needed...
Or if it works fine then run what you got too...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-23-2009, 09:11 PM   #7
Wildstreak
Wildstreak's Avatar
after sitting for three years the truck fired up like nothing, gotta love chevy!!! since I dont know what type of rig it will become, I'm just goin to replace things as they break, well that is except for the two barrel carb, thats gotta go asap!
57 chevy 4x4
68 burb 2wd:
Old 04-23-2009, 09:17 PM   #8
msgross
msgross's Avatar
Just make sure there is plenty of oil in the front axle since the entire tube is filled and tend to leak over time.
The Garage:
Old 04-23-2009, 10:58 PM   #9
Wildstreak
Wildstreak's Avatar
the front drive shaft is broken right now so 4wd isnt working, but I will check that in the morn to make sure its full. Thanks for the heads up
57 chevy 4x4
68 burb 2wd:
Old 04-23-2009, 11:21 PM   #10
msgross
msgross's Avatar
If the hubs are not engaged then it won't matter... the front axle won't move or need oil...
The Garage:
Old 04-23-2009, 11:30 PM   #11
Wildstreak
Wildstreak's Avatar
Thats what I thought, but i think I'll still take a gander at whats inside just incase
57 chevy 4x4
68 burb 2wd:
Old 04-24-2009, 07:02 PM   #12
msgross
msgross's Avatar
You can confirm gear ratio's then as well.. There should be a number on the ring gear like 41:11 or 41 divided by 11 = 3.727272 (3.73's) or whatever ration you have.
The Garage:
Old 04-24-2009, 09:50 PM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
A nice benefit to changing to an open knuckle axle is a much better turning radius - I've got one truck with the closed knuckle and one with the open and the difference is pretty drastic.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-04-2009, 11:30 AM   #14
19684x4k20
I have a 1968 k20 closed knuckle i lifted it 6'' added a drag link still dont get a full right turn. cant find a steering arm or pitman arm to correct it "yet "
19684x4k20 is offline   Reply With Quote
