Old 04-24-2009, 03:38 AM   #1
z400rider8787
easy rust removal?
so i tore out all my interior stuff (heater dist. box, pedals etc.) last night because almost everything has surface rust and bubbly paint on it. its not really bad enough to need replacing but i really dont wanna have to scrub the whole thing with a wire brush. Is there a fast easy and prefferably cheap way to do it? has anyone used that rust converter stuff? thanks
z400rider8787 is offline   Reply With Quote
Old 04-24-2009, 03:39 AM   #2
z400rider8787
Re: easy rust removal?
i would also like to use the same stuff for my chassis if possible to save some money... thanks
Old 04-24-2009, 09:52 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
I'd use a wire wheel on an angle grinder.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-24-2009, 10:11 AM   #4
sjarrett71
sjarrett71's Avatar
I've never used the rust converter but I'm sure someone that has will chime in.
Those pieces are so small it shouldn't take much to sand by hand and repaint. Or use a wire wheel or something similar. You could always get some chemical stripper also.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 04-24-2009, 10:21 AM   #5
monte0185
monte0185's Avatar
Easiest and fasted way is to put a 4" wire wheel on a a handheld grinder and go to town. Thats what im gonna be doing anyway as mines the same way.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-24-2009, 12:01 PM   #6
tim21391
tim21391's Avatar
wire wheel, 40 grit sand paper, wax and grease remover, rust convertor primer, undercoat is what i did to my frame, and high temp paint on exhaust.... here ya go
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-26-2009, 07:38 AM   #7
z400rider8787
that frame looks pretty good... so i got a wire wheel and went to town like you said it really wasnt too bad i got most the parts done in a day.
Old 04-26-2009, 08:07 AM   #8
ajcan
ajcan's Avatar
I have used a product called "rust-mort" before but not in an automotive application.It works very well but you still have to take a wire wheel and knock off the loose stuff.
AJ
ajcan is offline   Reply With Quote
Old 04-26-2009, 08:55 AM   #9
mplex2000
mplex2000's Avatar
I like electrolisys. Take a bucket of water with little baking soda. Now get your car battery charger, connect + to a steel rod or other scrap and make sure it's in the water. Don't put charger clamps under water. Connect - clamp to rusty piece and soak. Trust me, it works and it works good. Google for more info.
mplex2000 is offline   Reply With Quote
