Bed Wood Finish
OK I got my truck back from paint last Sept. and have been slowly puting it back together. The paint was a big pocket book "ouch"!!!!!!!!!! Anyway's I am getting close to finishing my bed wood. I have decided on Marine grade Spar Varnish. I want to buy the stuff here in town and what I am leaning toward is McClusky"s. Anybody's views or opinions on this prduct or any other suggestions? I took my truck out the other day and took a cell phone pic, and it needs washed real bad but what do you think?? And yes the wheels are just temporary.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
motor exploder
Re: Bed Wood Finish
not sure about the bed wood varnish (although any info would be great since I'll be replacing my bed wood soon), but your truck looks awesome. Is that a late model GM color?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Its the paint code for Eleanor the mustang off the movie gone in 60 seconds. Thanks for the compliment
Re: Bed Wood Finish
I have heard that you either want to use a marine grade finish as you mentioned, or find the stuff that they use on gym floors. That is supposed to be the toughest stuff. I did mine a couple years back and listened to some cheese ball that didn't know his varnish from a hole in the ground. When I find the time, I need to redo mine in a bad way! Keep us posted on how it turns out
I am a Referee of life.
Re: Bed Wood Finish
Bed wood needs to be sealed on all sides.Make sure you do the end grain and side grain also.I would recommend a marine grade varnish or better yet an epoxy like used on strip built canoes or kayaks.It can be had with a higth gloss and since it waterproofs and seals it seems like it would be the ticket.The downside is it has no UV protection so if the truck will be outdoors for any length of time I would also clear coat it with Automotive clear.
This is strictly the opinion I formed after reading thru some of the posts on this site. http://www.mikenchell.com/forums/ I figure if these folks spend all that time and effort to build something that looks that good they probably have done a lot of research on what works to keep wood nice.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Keep On Keepin' On
Re: Bed Wood Finish
Posting so I can find it again down the road...nice opinion panel
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
#7 | |
Re: Bed Wood Finish
Every kind of SPAR varnish that I have ever seen has UV screeners and/or UV absorbers. As long as it is rated for exterior use, you should be ok. It big question is "color" and gloss. Part of the sun blocking ability of these types of finishes is in reflectivity, so they are all full gloss. So you are kind of stuck with that, but that is what most people are looking for anyway so.....
Color is part of it too. Most varnishes are at least slightly amber colored and the more coats applied, the darker amd more noticable this becomes. If you are staining first, be aware of that and pick your stain accordingly, it will get darker. I have used THIS with great results. It flows nice and builds quickly.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Re: Bed Wood Finish
the first coat or 2 should be thinned quite a bit to allow for deep penetration into the grain of the wood //its very important to do all edges and ends of the wood to complete seal the wood so it willresist allowing moisture being absorbed by the wood// after every 3 or 4 coats lightly sand to get it smooth
Re: Bed Wood Finish
With the color of your truck the product they use on Trucks on the 64 would look awesome. nice truck.
Re: Bed Wood Finish
love the color....dont know anything about the wood bed though,,,sorry.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Re: Bed Wood Finish
I used the man-o-war spar varnish when I did mine last summer with good results. I used their satin finish and I have 4 coats brushed on both sides of the boards, which did take a little time to finish. If I do another I might also consider spraying automotive clear, it also offers excellent UV protection and would be a bit more fun than brushing on the finish.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
Re: Bed Wood Finish
I used Bristol Finishes 2-part marine varnish and topped off with 4 coats automotive clear. As chipflyer said, spraying is much easier.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
#13 |
Saving 1 truck at a time!
Re: Bed Wood Finish
McCloskey's, Man of War is a great marine spar varnish. That is what I use on my boat bright work and on just about any wood I finish. I love the old school bright work...8-10 coats...looks like glass!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 04-25-2009 at 09:03 PM. |
#14 |
Truck Parts Mfg.
![]() Join Date: Jul 2005
Re: Bed Wood Finish
70short: Nice looking truck. They build those Eleanor knock-offs up the road from us. It is an awsome car.
We have done tests on bedwood finishes for several years. You might be interested in looking them over. http://www.mar-k.com/wood_finish_testing_ii.html We tested Man-o-War in 2004 and it didn't last particularly well. If you require long term durability in the weather, consider painting the wood as in our test. Gloss black exterior paint over 3 coats of POR-15. No other finish tested comes close. This test has been going outdoors 24/7 in Oklahoma weather for 4 years and the black painted wood has zero failure, still looks nice. All others failed to some degree in less than a year. I could see glossy black or charcoal color wood with aluminum strips in your truck. Mar-Ktech
GET MAR-K Quality! Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks |
#15 |
Re: Bed Wood Finish
The truck will spend most of th etime parked in my garage. other than when I am driving it which will probably be only in summer type weather. I do have a daily driver that gets way better gas milage. Plus I have another hot rod to share the spot light. and my wifes daily driver is a 04 BMW M3 and that is alot of fun to drive.
