Rear control arm bushings.
I have done a search and didnt come up with alot on this. I have a couple questions.
1. I pull a 16ft trailer alot with cars/trucks/atv's you name it i pull it practically. Would switching over to poly bushings help in stabilizing the rear end any from swaying? If not/so what do you suggest. 2. How do I go about replacing them. I've read press the old ones out as well as burn and replace. Are there better or more proper options? Thanks in advance. Terry J.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
Under Construction
Re: Rear control arm bushings.
A rear sway bar would probably be your best bet. you can place a socket over the bushing and push out. I have heard of ppl using c-clamps, and ball joint removal clamps as well.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Yeah a rear sway bar is on the list next time im at the junk yard along with a few other things.
