Old 04-24-2009, 04:15 PM   #1
WorkinLonghorn
WorkinLonghorn's Avatar
Two-piece drive shaft phasing
I must have been asleep during this lesson.
I have a two-piece DS that vibrates and seems to go through middle u-joints too quickly.
Does anyone have a diagramn or description of how it is supposed to be phased? There is no special "alignment spline" like the haynes manual describes.
Thanks! WLH
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 04-24-2009, 04:24 PM   #2
WorkinLonghorn
Re: Two-piece drive shaft phasing
OK I think I've got it; The transmission output flange is parallel to the one behind the center bearing and there's only the chance that one section is 180 degrees off, right?
Anyway while ;looking at it I noticed that the rubber thing aroung the center bearing alows the shaft to move at least 1/2 just with hand pressure and yet another u-joint is showing some play.
Old 04-24-2009, 04:55 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
does this pic help any??...This is how the driveline shop set mine up...and I haven't had any issues...
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-24-2009, 05:19 PM   #4
LONGHAIR
Well, from the looks of it, gcburdic, yours is off (out of phase) but that appears to be in the welded section. I suppose that since it is the section that is held by the carrier bearing, it "theoretically" doesn't have an "opposing" joint on the other end. The important part of the phasing would be between the middle and rear joint. Those two would need to be aligned.
The joints are supposed to be "in-line". Say you lay your drive shaft on the garage floor, standing on the "flat" of the yoke. Then all of the joints should stand the same way. Now, I know that your carrier bearing is in the way of this, but you get the point? When they are aligned like this, each joint is doing the same thing, meaning compensating for the angle of the drive shaft, at the same time.
Many times there is a "dead" spline that will only let it slip together one-way...but not always. All of the others I have seen have had an odd number of splines. This makes it so that there is really no way for it to be assembled 180 degrees out of rotation. Even if this wouldn't effect the phasing, it could effect the balance of the shaft as a whole.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-24-2009, 05:30 PM   #5
tucnnuts
if they can make it so can I!
tucnnuts's Avatar
i agree with longhair... the yoke are suppose to be inline , the two peice i used had two of the splines angled in a lil bit to index it...i have also had to put a slip yoke in the rear to help reduce the stress on the hanger bearing....mines not in the stock location but on a stock height truck , is it important to have the truck on the gound before you tighten the bolts in the hanger bearing or does it not matter?i have the wine glass style not the pillar block kind...
tucnnuts is offline   Reply With Quote
Old 04-24-2009, 06:06 PM   #6
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Not to jack the post but....gcburdic...how do those flows sound dumped under the truck like that and can you carry on a conversation next to you in the cab? trying to get ideas on my exhaust...are those 2.5 or 3 in pipes? Thanks
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 04-24-2009, 06:16 PM   #7
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
have you checked your transmission mount(s)? if they go bad, and are not replaced, they will take the carrier bearings and ujoints with them.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-24-2009, 06:37 PM   #8
cdowns
cdowns's Avatar
its not that expensive to take to a driveshaft shop to have new installed and shaft balanced
Old 04-24-2009, 07:29 PM   #9
WorkinLonghorn
The cheapest of the two DS shops around here told me $160 to balance a two-piece, which I thought was excessive.I did get him to look under, and he said it was out of phase.
It seemed good with just my two hands acting on it, I'll maybe look at it while applying some power through the trans and see if it moves,but i think it's OK.
Old 04-24-2009, 07:42 PM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
Well crap....I guess I'll run it over to them and have them take another looky....I really appreciate you input Longhair....I'd hate to be rollin' and have it go ca-put!!!....Thanks again! Geoff
CoachMeason...PM sent
Geoff with a G
Old 04-24-2009, 10:35 PM   #11
Green Machine
Green Machine's Avatar
Should be like this - each "long" piece should have the ears lined up -
yoke hanger Rear
==[0==========0]============[0
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-24-2009, 10:46 PM   #12
WorkinLonghorn
Hmmm. OK I think I have it now,thanks everyone.
BTW,For what it's worth the Haynes manual says for a 4WD (mine is 2WD)rear shaft you line them up and then rotate the rear section 4 splines counter clockwise.
Old 05-11-2009, 06:00 PM   #13
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey Guys,
I wanted to bring this back to the top, and don't mean to hi-jack this thread, but I think it applies?!?!?
I stopped by the shop that balanced the driveshaft and installed the carrier bearing....he looked at it again and said that he knew it was 1/4 turn out, but said that is how some of them came from the factory?!?!....
I really didn't notice any vibrations while driving it home, but I can't say there isn't one.....ugh....should I take it to another shop and get it in phase, or should it be okay??
Thanks for any input!!!
Geoff with a G
Old 05-11-2009, 06:36 PM   #14
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Geoff, just for peace of mind take it to another D/S shop and let them give you a second opinion.....
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 05-11-2009, 08:10 PM   #15
brad_man_72
the boat guy
brad_man_72's Avatar
some 1st gen camaros were 15* out of phase. i cant imagine a ds shop would leave the shaft out of phase when they were going to ballance anyways. their are a ton of people that think they know how to build a driveline, most of them dont have a clue.
ive seen mechanics SLIDE a driveshaft apart get the yokes out of phase with a blind spline then use a BFH to BEAT the driveshaft back together, ruining several expensive pieces of the ds.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
