04-24-2009, 05:48 PM | #1 |
Old member
? for all of you
I have been working on these trucks for years and I saw something yesterday I never saw before.
A friend of mine has just bought a 70 truck. Very nice truck and he has already joined this site because of it. We were trying to find out what was wrong with the fuel gauge, why it wouldn't register. With the truck running it showed empty. I hooked my test light to the wire connection that hooks to the tank and runs to the fuse block. I then touched it to the tank and it read full which is where it should have been. My ? for all of you is would this work as it suppose to if you added a little light to the wire or even a resistor inline so it would read right or would it read full all the time?
04-24-2009, 06:40 PM | #2 |
Re: ? for all of you
did you try to just install a ground wire from the sending unit to the body?
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-24-2009 at 06:40 PM. |
04-24-2009, 07:07 PM | #3 |
+1
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
04-24-2009, 08:15 PM | #4 |
Old member
NO,
I didn't really know where to start. The tank should be already grounded to the truck since it's bolted in right. Is there a wire suppose to be on it someplace?
04-24-2009, 08:43 PM | #5 |
tank may be grounded sending unit not because sometimes the rubbeer oring inteferes with ground // i dont know if its"supposed"to b grounded i always ground them and my gauge wworks when i do
04-24-2009, 09:11 PM | #6 |
I am a Referee of life.
^ What cdowns said.^ I have had a couple that didn't work and grounding them always solved the problem.
If you put a resistor or a light bulb in line then the resistance that causes 'graduation' in the guage would change.It might be a fix if the guage were for 90 ohms and the sending unit for 60 ohms,if the resistance changed by 30 ohms.IIRC these were the two stock resistances on these trucks.Even this may not be accurate since the sending unit is basically a variable resistor and adding resistance may cause it to read off unless completely full or completely empty,I don't remember which end is the higher resistance.This info is simply my opinion since it has been years since I learned/used any electrical thoery and I suppose it doesn't really apply but I typed it so I'm leaving it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 04-24-2009 at 09:14 PM. |
04-24-2009, 11:04 PM | #7 |
If you unhook the brown wire at the sender, gauge should go past full, ground that wire and it should read empty, this verifys the gauge and wire, switch needs to be on of course.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-25-2009, 02:09 AM | #8 |
Old member
With truck running and wire loose the gauge went to way past full. When you hook it up it goes to empty and stay's.
04-25-2009, 01:11 PM | #9 |
its all about the +6 inches
sounds like a bad float in the sending unit.
04-25-2009, 01:16 PM | #10 |
04-25-2009, 01:33 PM | #11 |
Old member
I have my old sending unit that we checked it out and it seems to be working. I ran out of time to install it for him so we plan to do it another day. My ? is though would the small light bulb work in a pinch if need be. Say until you could get a new sendor. Just wondering!
04-25-2009, 01:39 PM | #12 |
I'm not a fan of the light bulb idea to check the resistance. You can buy a multimeter for around 10 bucks at Sears most of the time or about 4 bucks at Harbor Freight. The inexpensive ones will tell what you need to know and if you have one you will find yourself reaching for it more often than a test light.
I almost always have a good test light in my truck but more often than not reach for the multimeter first. Last edited by mr48chev; 04-25-2009 at 01:39 PM. |
04-25-2009, 02:43 PM | #13 |
Old member
I have about a $100.00 in my meter. I use it for trouble shooting electric golf carts all the time.
I was asking if the light bulb resistants would make the gauge work properly. It made it read full right but will it read as the level in the tank goes down or will it stay at full? This is my ?
04-25-2009, 04:14 PM | #14 |
One day.....
I had the very same problem. Everything checked out. It turned out to be the sending unit itself. you can pick them up for about $30.00.
DZL1. |
04-25-2009, 05:03 PM | #15 | |
Msgt USAF Ret
The only problem you have is that there is no way to vary the light resistance, so the gauge will read constant.Your test light must be close to 90 oms for the gauge to read full when you connected it to the brown wire. Below is a picture of how the sender varies the resistance.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 04-25-2009 at 05:04 PM. |
04-25-2009, 05:24 PM | #16 |
Old member
Brown wire connected to the fuse block and to the sendor. I could disconnect either end and place my test light on either end and it would show full. Would it drop down while the level drops?
Also what do you think we need to do about his. I have my old one we plan to install.
04-25-2009, 07:52 PM | #17 | |
Msgt USAF Ret
Pull his sender and repeat the test and if it checks good then you need to determine why the float arm is not moving in his tank. I think that is what the other guys have been trying to tell you also. At any rate do not put any positive voltage on the tan wire while it's connected to the sender in the tank. It could cause a fire and burn down the truck or worse.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-25-2009, 08:11 PM | #18 |
sharp as a marble
IF, everything is good from the sender to the gauge, you should be able to touch a grounded test light to the sending unit wire and IF you look carefully, you will see a very dim light, that will pulse. If you see this the all should be good to the front. Been beat up with a lousy ground at the tank. Clean the ground and reattach. Someone else posted that this might be a ground issue.
04-26-2009, 02:57 PM | #19 |
Today I grounded the sending unit with no luck. Then hooked a meter up on Ohms. 2.1 ohms. Inserted a metal rod into the tank,moved float up and down, Ohms and gas gauge followed. It is definetly the float/sending unit that is bad. Thanks for everyones input Andy made the initial post as I'm a new user. Thanks Mach1
04-26-2009, 03:19 PM | #20 |
Old member
Cool Mach1. Good deal, we just need to get the old sendor out of mine and install it. See you at work tonight. I will get it out and have it ready to do whenever.
Mach1 is a friend of mine who also works with me. Hope to see him on here a lot more in the future. He bought a 1969 Chevy 1/2 ton short bed. Very nice truck! I'll let him give all the details when he is ready. I like the color though it's the one in his Avator. You going to drive it tonight.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 04-26-2009 at 03:19 PM. |
