Spitting fire..lol
As of late when I drive my truck and park it and then try to crank it back up.It's having to turn over more than when I first got it.So today I took it for a spin stopped by a family member's house for about an hour,and sure enough when I tried to crank it,it started turning over but not firing.So I pressed the peddle a couple of times and after a few more turns it cranked.So I got to the corner and stepped on the gas and heard it back fire and cut off.Then i cranked it back up and drove to the store to get a pack of smokes and when i got out I saw smoke.So I popped the hood and fire was shooting up out of the carb.I didn't have any thing to put it out with and the ppl in the store saw what was going on.So they came running out the store with a fire extinguisher.And proceeded to coat my whole engine bay with this stuff.
If it ain't a chevy,I don't want it |
Re: Spitting fire..lol
That sucks! Sounds like your timing is abit off. On my burb when i put my new intake and carb on, i was ripping around when it wasnt timmed right, when i hammered on the gas it would shoot a 4 foot flame out of the carb. Id try timing it again
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's Last edited by Hoffman65burb; 04-25-2009 at 03:29 AM. |
its all about the +6 inches
and double check the vac advance canister, make sure it is working.
Eat My Rust
Ay, the joys of engine timing!
My neighbor was able to pop out a 3 foot flame while we were getting his cougar in time. My truck had only one foot. |
ironic huh you wanted to smoke and so did your truck
dazed and confused
also might want to check and make sure the dizzy hold down bolt is tight. it could be loose and be giving you problems. i had this happen once
members met: redbaron69, billsbowtie,nc67 |
