Truck Fanatic
engine question
i've got an 87 gmc jimmy s15 4x4 2.8L FI. i need a new block for it, does anyone know what year range of block will fit besides 87?
thanks Last edited by eraser87; 12-26-2002 at 10:31 PM. |
I would skip the 2.8, try a 4.3 I like the power better for that size of truck. I've got a 92 with a sport exast with the 4.3 It turnes the tires very good. With the 4x4 you will like the hills better too.
Whats this wire for?....
To do a 4.3 swap, you'll need the transmission, and engine subframe too. Might as well just drop a 305 or 350 in it instead.
Kyle CANADIAN CONNECTION'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders |
Wouldn't you also need the computer out of the vehicle with the 4.3? Along with some of the wiring?
"When I start my car in the morning I want the neighbors to think the world is comming to an end." Homer Simpson I'm not stuck, I've still got some gas left" |
king $h!t
forget 350 put a 6.2 diesel now that would have lots of power
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s |
Your right "J" I'm thinking too small a 350 would sure turn some heads at the light!
| Bookmarks |
