When I bought my truck and drove it home from Oklahoma, I never noticed any blue smokey haze in my rearview or side mirror. Now, several months later, when I take it onto the hwy, I see the blue haze behind me.
I'm not sure what the PO was using for oil, but I've been using Castrol 10w-30. Now I'm beginning to wonder if that's the reason for the smoking or could it be something else? Nothing else is making any noise or vibration of any kind, so I'm a little puzzled. Not to mention, it's embarrising for my classic to be leaving that kind of haze for others to see or drive through. Anybody have any ideas or similar experiences? Thanks, Greg |
#2 | |
Re: Truck Leaves Blue Smokey Haze on Hwy......
...Ron
68' SWB Stepside (bought it on a whim for a winter vehicle, not ready for prime time yet, should be soon) 68' RS Camaro (Almost finished project) 88' Formula Bird (near future project) 00' GT Mustang Vert (daily driver) |
I'll hope for the simple part. I do know that the chrome valve covers are not sealing down real good. I've got an original set given to me by an older gentleman here in town that I plan on putting on w/some new gaskets. Maybe I'll get lucky and that'll fix the problem.
Greg |
if you've got cheapo chrome valve covers with no baffels and a PVC system the carb is sucking the oil into the engine causing the blue haze now dont confuse that with purple haze cause thats a whole different thing
Active Member
![]() Join Date: Jul 2007
Rule of thumb: Bluish smoke when you first crank it up or after it sits for a while, usually are the valve guides. Bluish smoke on the highway at higher speeds, usually rings.
I say rule of thumb because there could be a combination of things causing the haze, as mentioned. Since you're not familiar with the engine or what's been done before you got it, it would definitely be wise to start with a compression check and check all of the easy problem areas. My guess is with the rings. |
#6 | |
Always Fixing Things
Just an Average Joe ![]() ‘68 GMC 307 3spd – My dad's original truck 310,000 miles Last edited by SacramentoJoe; 04-25-2009 at 09:30 AM. Reason: typos |
It doesn't smoke any at start up or when I am cruising through town (35-45 mph), but when I get on the hwy and do 55 or above......I see the blue haze behind me.
cdowns......No purple haze seen, nor have I been kissing the sky. LOL! And yes, that would be a very different thing! Greg Last edited by ashx2; 04-25-2009 at 09:58 AM. |
Active Member
From the way you describe it, I'd suspect the rings. Oil thins out after it gets hot and seeps past the rings at higher speeds.
It could be the rings are stuck with carbon buildup. If you're not thinking of a rebuild right now, maybe some oil or fuel additives my loosen them up. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Gotta admit my first thought about your truck leaving a trail of blue smoke was...... Too much torque for the tires to handle!!
![]() But you got some great advice above... check the VC gasket -- rings may be the most likely issue -- leakdown test is your best bet to find out for sure. You might be able to buy some time with 20W50 oil.
Its a Truck Thing......
Also check to see if the oil drain holes in the head are clogged up. I had a 350 that had that and they were full off crap which led to the situation you described. Cleaned them out and no more problems. Must have been using Quaker State
![]() Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 04-25-2009 at 11:34 AM. |
