Old 12-26-2002, 07:21 PM   #1
fastbagged68
fastbagged68's Avatar
Is there a difference between a short bed and long bed trailing arm
Is there a difference between a long bed and short bed trailing arms? I have ashort bed frame with trailing arms but I have a 63 carry all/ suburban and want to know if the arms are the same lenght.
fastbagged68 is offline   Reply With Quote
Old 12-26-2002, 09:11 PM   #2
Primer_72
User and Abuser
No...
RIP....
'99 Sierra 2x
'93 Sierra 4x
'72 C-10
Back in business: 68 C-10 lwb
Primer_72 is offline   Reply With Quote
Old 12-27-2002, 10:39 PM   #3
JHickson6
I Love This Stuff!
JHickson6's Avatar
That was the quick answer and he is right, the only thing that varies in the different truck lengths is basically the frame and of course the box. The crossmember that the trailing arms mount to is just moved further back in the frame than on a short bed.
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 12-28-2002, 05:46 AM   #4
COBALT
COBALT's Avatar
Between 3/4 ton and 1/2 ton the arms will be reinforced with steel plates.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 01-07-2003, 02:33 AM   #5
Scrub
Collector of rusty Items
Scrub's Avatar
Sorry, I didn't get that. Are 3/4 tons stronger?
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 01-07-2003, 05:17 PM   #6
COBALT
COBALT's Avatar
Yes. They have to be assuming the weld points are in good shape.
The steel reinforcement is to increase the modulus of elasticity of the "I" beam. It's like taking a header beam over a door or window, and nailing plates to the top and bottom. Since the beam is in compression at the top and tension at the bottom the shear force can be withstood with an extra layer of steel. That way the stress isn't just distributed through the top half and bottom half of the "I" beam, but through the weld points and the plates as well. Larger cross section means less deformation due to elastic displacement. Compression and tension will be concentrated on the plates (1/4") instead of the "I" beam flanges (thinner - 1/8" - 3/16") You'll see less flex in the center of the span, and therefore, less stress cracking on the flanges.
You could have them custom welded and you'd have stronger-than-hell trailing arms!
Seattle, WA.
