![]() Join Date: Dec 2008
Chassis, engine, etc...
72 C20 3/4 ton rolling chassis, 8 lug front and rear, disc brakes in front, power steering. Selling complete $300
92 Small block Chevy engine 350 4 bolt main, was running when parked in mid January. Comes complete with, Manifold, 4 bbl carburetor, distributor, fuel pump, alternator, intake manifolds, exhaust manifolds, starter. Number stamped on block is 10066038 online code description says it is a Goodwrench crate motor, 2-piece rear seal. $300 3 Speed 3/4 ton truck transmission. $100 Brake master cylinder and booster SOLD Brake and clutch pedal assembly $35 plus Shipping Steering wheel and column for standard transmission, green, needs work. $25 for both plus Shipping Behind seat gas tank SOLD Stock seat, frame is in good condition, cloth is worn with one rip. $20 Rear window glass $15 Instrument cluster, complete. $40 plus Shipping Complete heater system with dash controller SOLD Glove compartment door $5 plus Shipping Green sun visors $10 plus Shipping Can email other pictures if needed. Thanks |
low n' slo
![]() Join Date: Mar 2009
Re: Chassis, engine, etc...
would the motor turn on now or is there no way to try it?
It cant be started now that I know of. If I were to keep it I would re-build it because I dont know how the previous owners treated it. The oil that is in it is clean and free of particles or debris of any kind.
If you know of a way to fire it up as it sits Id be willing to give it a try, Id have to get a coil though. I dont know how much of the harness or wiring we would need to get it to run as it sits. If you want to come see it or talk P.M. me your number. Ill be available all day tomorrow. |
is the column a tilt floor shift? if so what does it need
The column is not tilt. It could use a rebuild. Everything is there but its all loose.
how much for the column shipped to 48382?
As far as I can tell, shipping is going to be around $20 give or take a few dollars. I would send it at two separate packages.
At looking at the steering wheel again its from a 73-78 truck rather than the stock 67-72. Send me a P.M. if you are still interested. |
Engine is Sold!
Price on complete rolling chassis is now $250.00 or best offer.
Thanks |
