Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-25-2009, 02:05 PM   #1
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
Ignition Wiring
Hi,
I'm trying to remove the plug off of the back of the ignition cylinder. I don't see any clips that are holding it in place. This is the original wiring harness. How do I get the plug off without ripping the wires out. - Thanks.
72blazer_mud_bogger is offline   Reply With Quote
Old 04-25-2009, 05:55 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Ignition Wiring
it has 3 press in prongs for lack of a better description. Look under there with a flashlight, you should see them.
Total PITA.
Old 04-25-2009, 06:36 PM   #3
UltraBlue71
UltraBlue71's Avatar
Re: Ignition Wiring
Ya gotta love old plastic brittle as hell!, I pried mine off with a small slender tipped common screwdriver
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 04-26-2009, 01:10 PM   #4
72blazer_mud_bogger
Re: Ignition Wiring
yeah i finally got it off and managed to not break anything when they came off. thanks for the help though
Old 04-26-2009, 06:18 PM   #5
Longhorn Man
Re: Ignition Wiring
when you put it all back together, make sure to add some dielectric grease on the contacts. This connection is a known hot spot that melts in stock trucks, start adding electrinics, and that pink wire gets hotter and hotter.
Old 04-26-2009, 06:30 PM   #6
72blazer_mud_bogger
Re: Ignition Wiring
good to know thanks
ignition, wiring
