Old 04-25-2009, 06:30 PM   #1
TooT
Active Member
TooT's Avatar
Screws for a/c vent housings?
I need to know what size screws or the length of the screws that i need for the ac vent housing on the jimmy....any help would be appreciated!
TooT is offline   Reply With Quote
Old 04-27-2009, 11:15 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Screws for a/c vent housings?
The top screws are 2 1/4" long oval head trim screws. The two bottom ones are 1/2" long oval head trim screws. Just in case you aren't familiar with them, trim screws have a smaller head than regular oval head screws. Check with your local body or upholstery shop. They usually keep a good supply of oval head trim screws on hand. The long ones may be a problem though... If you use regular oval head screws don't tighten them all the way up or you will crack the vents....
LockDoc
Leon
