Old 05-15-2002, 07:47 AM   #1
cam
Post tires and rear end ratio
Just curious what size radial tires are closest to stock on a 70 c10. I have the original 78 LT 15 as the spare but the original owner put 215 SR15 radials on the pickup and they look small.
Also was wondering if there was a set rear-end ratio for pickups with the 350/auto/heavy duty rear springs options. I took the pickup out on the highway last night and it seems to be reving to high at speeds above 50mph.
Thanks again
1970 GMC 1/2 ton 307 4spd
1970 dorF dump runner
cam is offline   Reply With Quote
Old 05-15-2002, 10:34 AM   #2
texnician01
texnician01's Avatar
Post
take your truck, jack up one wheel (rear) and put the tranny in neutral. (make sure to block the front tires) and turn the wheel 2 full turns. count how many revolutions the driveshaft makes. this will be the rear end ratio. if it turns 3 times and just a little more it is a 3.07 if it turns 3 times and most of a fourth then it is a 3.73, if it turns 4 times and a little more it is a 4.11. this should get you close anyway. I have some gearsets and carriers if you are looking to change them. as for tire size I have 235-75R15's on mine and they look pretty good.
Nathan
1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road.
55 chevy 4 door 150
47 Willys CJ-2A
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 05-15-2002, 11:06 AM   #3
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Post
Hey texnician01, do you have any carriers for a 3.07 ring and pinion. Series 3 I think? Email me @ nt_expert@hotmail.com
67 Chevrolet LWB with rebuilt 292. 415 ft. lbs of torque, 4 speed, 3.73 Posi, straight and almost painted.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 05-16-2002, 09:51 AM   #4
cam
Post
I bought 235 75 15's yesterday, much nicer, and it seems as though the rpm's are a bit lower at highway speeds. I'll try the rear-end ratio suggestion tomorrow. Thanks!
Old 05-16-2002, 10:37 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I have 3.07 gears on mine. With the 275/60 15 inch tires, the speedo is 100% correct. That means it is the right diameter. (28 inces tall I think)
RPM's are not too bad either
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-16-2002, 10:44 PM   #6
Zkast
Zkast's Avatar
Post
If the Speedo is correct... better hope that gas gauge is NOT lol
Pictures and more...
Email me
'71 LWB
350/350T, PS/PB
Special options? Yes, RUST... Need some?
Garrett
Olathe, Kansas
Zkast is offline   Reply With Quote
Old 05-16-2002, 10:46 PM   #7
Longhorn Man
Post
LOL, it is right too, it will sputter and p!ss me off at the 'M'. I still had a few miles to go ...not worried yet.
Columbus Ohio
