12-26-2002, 08:09 PM | #1 |
Converting to posi???
I was wondering if any of you all had converted a regular rear end to a posi at a reasonable price. I know you can buy the posi unit from summit and jegs for a chunk of change, but I was hoping there was a more reasonable way to do so. Any info you have on how to do this, where to buy the parts, pics, etc. would be greatly appreciated.
Thanks in advance, Riley
72 Chevy short stepside 350/350 tilt, vintage air a/c sunset Orange Metallic paint Early Classic 2.5/4 drop eagle series 211 wheels |
12-26-2002, 08:23 PM | #2 |
Used to have a truck
sure did . Have done it several times. This one is a detroit locker. Paid $75 from the junkyard for the complete rear end. Then I swapped the carrier into my housing. Took a couple of hours.
No truck :-( |
12-26-2002, 09:59 PM | #3 |
posi
Not everyone is as lucky or as mechically inclined as mikep .I'm glad I am.$50 junkyard rear with bad bearing and axels.$103 new carrier,pinion,axel bearings,seals,grease and limited slip additive. I think i"ll put some fresh scatch marks out tomorrow and let the 5.0s know mighty mouse has been out of the shed.You should see how they act when they get dusted by and old truck put together out of parts.ie All doors fenders hood etc are different stock colors . They call it spot.
12-26-2002, 11:43 PM | #4 |
Somebodies dad made them put their tools away ! Right on !
No truck :-( |
12-26-2002, 11:55 PM | #5 |
Fabricate till you "puke"
Hell yes! spank them ferds.....I have a theory, if I cant out run em......Ill just run em over
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
