Old 04-25-2009, 10:17 PM   #1
eke82
81 gmc any aftermarket options for cruise control?
I have a 81 gmc 2wd sb i want to reinstall cruise back on it. When i bought it was a rolling shell so i have none of the factory items. Is there a place to buy oem or does someone make a aftermarket setup?
Thanks eric everingham
eke82 is offline   Reply With Quote
Old 04-26-2009, 01:36 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: 81 gmc any aftermarket options for cruise control?
OEM from local wrecking yasds. Or check out www.dakotadigital.com for aftermarket set ups.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 04-26-2009, 04:58 PM   #3
OrangeAnimal
OrangeAnimal's Avatar
I would use the Dakota Digital they sell top notch stuff. For me to add it would be no biggie since I already have there gauges they make for the 73-87 trucks. They are sweet!
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 04-27-2009, 02:29 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I use a www.rostra.com unit. Works great. It will pull the throttle all way open if necessary to get back to the set speed! I've had it engaged and it would kickdown the tranny and accellerate. The unit is easy to install.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-28-2009, 10:32 PM   #5
eke82
Thanks for the options
eric
Old 04-28-2009, 11:27 PM   #6
gchemist
gchemist's Avatar
I've installed two different types on my trucks. The first is a unit from Audiovox.
Electronic Cruise Control ZX810344U Each $155.99 @ www.jcwhitney.com. It costs $99 when I bought it several years ago!! The unit is easy to install. Instructions are not well explained. It does need a vacuum resevior for small engines. Yours may be require two reseviors or one large one. The control pad can be installed below the light switch.
My 83 Chevy has a unit from http://www.rostra.com/cruise-control.htm
The units from Rostra are used by hot rodders. It's awsome. It will pull the throttle all the way open if necessary to reach a set speed!! I use the vacuum unit. The electronic version is probably better. The cruise cost is twice the Audiovox unit.
Old 04-30-2009, 10:26 PM   #7
eke82
how hard was the second unit to install?
thanks eric
Old 05-01-2009, 07:56 AM   #8
gchemist
gchemist's Avatar
Not very difficult. Check my webpage for photos. The Rostra unit works great!!
Old 05-04-2009, 10:39 PM   #9
eke82
what did you pay for it might i ask?
Old 05-11-2009, 08:06 PM   #10
gchemist
gchemist's Avatar
A few years ago, about $275. If you need a connection, I can probably help ya out.
Old 05-11-2009, 08:45 PM   #11
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
If you are willing to do some work, an electric unit from an 88 and later truck can be retrofitted. It needs an electric signal from your speedo cable (available for aftermarket efi from various places) and then hooks to your carb or throttle body. Since most of it comes from the wrecking yard, it can be done inexpensively. I understand it works much more reliably than the factory vacuum units and uses the original steering column controls.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 05-12-2009, 02:41 PM   #12
low sierra
Old Time Rodder
low sierra's Avatar
Go with a Rostra electronic unit, you won't regret it. Easy to install and works great.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980)
Replacement cab had A/C which now works, made a real truck out of it
84 MC 305 350TH 3.08
4 wheel disc finally
My daily driver again
low sierra is offline   Reply With Quote
