Old 04-26-2009, 03:02 AM   #1
Black-Dragon
brake problems
my dad and i started working on his 68 after its been sitting for 6 years we put in a new master cylinder in and bled the brakes a few times each time was a constant flow of fluid but the peddle still goes all the way to the floor and is soft. any suggestions
Black-Dragon is offline   Reply With Quote
Old 04-26-2009, 04:36 AM   #2
wood
PooP
wood's Avatar
Re: brake problems
check your wheel cylinders for leaks and if you cant find any leaks you probably have air in the lines
wood is offline   Reply With Quote
Old 04-26-2009, 09:27 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: brake problems
Check all of the obvious as woods mentioned but if all looks good then the new master cylinder may be defective.
I went through three of them some years back until I changed parts store and got a different brand. Be sure and follow the directions explicitely on bench bleeding. You can do it mounted on the truck but requires two people.
When you bleed start with the rear passenger side and then the driver's side. Then front passenger side and then driver's side.
68gmsee is offline   Reply With Quote
Old 04-26-2009, 10:41 AM   #4
Black-Dragon
Re: brake problems
cool thanks a lot site sure is a big help
Old 04-26-2009, 10:49 AM   #5
Wrenchbender Ret
Re: brake problems
Make shure your brake shoes are adjusted up good.
Wrenchbender Ret is offline   Reply With Quote
