Chemist under the hood...
Alternator Bracket Pictures 1967 283 V8
OK, I gave up and took off the old alternator that was on a bracket at the bottom driver's side of the 283. The bolt was already broken off in the block and seized in the alternator. Torch got it out of the block but I couldn't get it out of the alternator. Bought a new Champion alternator with external regulator. Would someone be so kind as to post a couple of pictures of how it is supposed to go on? My block only has holes on the bottom driver side for mounting. The PO had the alternator bracket (the sickle looking one on upside down and the alternator pivot was all warped to make it work. I'd like to get it on right for a change.
Thanks in advance. ![]()
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
Re: Alternator Bracket Pictures 1967 283 V8
It is a little difficult to show the brackets but this is what I have on my 65 Impala which has the same mounting. The alternator bolts to the left manifold which has two tapped holes in the end. There is a stepped bracket that bolts to the manifold and to the water pump. The bracket just shows in the pic attached.
The adjustment bracket bolts to the front of the manifold. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 07-14-2009 at 12:52 PM. |
Thanks for the picture. I put mine back where it was with some long stove bolts and lots of washers for keeping the pivot tight. I would like to move the alternator up top but I'd have to do what you did. I saw some kits on the internet for the lower mount but they look like they use 3 holes on the block and I have only two. Maybe one is for the pivot?
Thanks again.
Jim,is your engine bay correct?Cause some of it is different from my 65.
Radiator and spacer is different as well as you have no shroud. And the front upper adjusting bracket is missing from your A/C compressor. Not to high-jack this thread or be picky.I've been trying to put mine back to original for some time and keep seeing conflicting arrangements. And you are correct about the alternator mounting.GM used that set-up for a lot of years on cars and trucks. ![]() Thanks,Mike. |
Here's my before and after pictures! Feel my pain!
Yeah thanks for the pics my alternator is the kind that mounts to the top and power steering below that.
