Old 04-26-2009, 10:10 PM   #1
1987_3/4ton_chevy
Cowboy Up
rear axle u bolt kit
hey question...
Is a Rear Axle U Bolt Kit something that obtainable locally at a parts store or specialty item online?
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 04-26-2009, 10:18 PM   #2
69lemans
Re: rear axle u bolt kit
Look in your local yellow pages for a place that sells springs and drive line parts. They can probably bend you some while you wait. It's a good Idea to take an old one with you to measure from
69lemans is offline   Reply With Quote
Old 04-26-2009, 10:23 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Here is where I got my new, longer "U" bolts for the 2" blocks I put in the White '67:
Merrill Axle & Wheel Services
1403 Walnut St
Des Moines, IA 50309
(515) 288-2131
LockDoc
Leon
Old 04-27-2009, 07:28 PM   #4
mbgmike
Thats what we do. And they do bend them while you wait and inexpensive to. If in small town its a problem though
mbgmike is offline   Reply With Quote
Old 04-29-2009, 05:12 PM   #5
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
well the issue we have....is we bought the truck from a junk yard, and someone had already pulled the rear u bolts and u bolt "cap" on top of the rear axle on both sides, so we have nothing to go off of
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 04-29-2009, 05:47 PM   #6
mr48chev
mr48chev's Avatar
Zach you might have to return the favor and find a set or at least the plates in a wrecking yard. If you hunt a bit you might even find a set of plates that are already off. Wrecking yard parts pickers are famous for taking a torch to the U bolts though.
You should be able to order the U bolts at Napa if there isn't a Spring shop near to where you live.
Or call the outfit that LocDoc suggested and see if they will make them and ship them. 120 Miles one way would be a beer run in some parts of west Texas but I don't know about Iowa.
mr48chev is online now   Reply With Quote
Old 04-29-2009, 11:43 PM   #7
okiefab
go to www.stengelbros.com every kind of u-bolt there is and as reasonable as anyone, i have order from them good service.
okiefab is offline   Reply With Quote
Old 04-30-2009, 07:37 AM   #8
Willy Prost
I got my new rear axle u-bolts from Bill Athey, one of our board vendors.
Big Brown truck dropped them off right at my front door.
Willy Prost is offline   Reply With Quote
Old 05-02-2009, 01:51 AM   #9
4x4Poet
Off Road Designoffers a u-bolt reversal kit.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-02-2009, 10:26 PM   #10
ProStreet83C10
Drag Racer
we dont need a reversal kit.....just an OEM replacement for rear axle, we need all 4 U bolts as well as the plate that sits on top of spring pack that threaded ends of U bolts stick through and tighten down on to
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 05-02-2009, 10:44 PM   #11
ProStreet83C10
Drag Racer
Edit: the plate sits under axle and U bolts hang down through it then get tightened onto it.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 05-26-2009, 06:14 PM   #12
1987_3/4ton_chevy
Cowboy Up
I found some u bolts but i don't have one to go off of. Does anyone know what size i need for a 1971 4x4 chevy truck? Is a half ton. Where is that website i found..... there are some sizes there
http://www.jegs.com/p/JEGS/JEGS-Rear...8-38db0de2603c
Or, how do you messure what size i am needing?
Chris Cary
