04-26-2009, 10:23 PM | #1 |
Cowboy Up
Chassis
We are getting down to the point of sand Blasting the chassiss of a 1971. Can we get help to what to look for on the frame and any known areas that tends to go bad?
1971 chevy k10 *Under the Knife* Chris Cary |
04-26-2009, 10:28 PM | #2 |
Re: Chassis
ours had a rotten cross member just ahead of the axel, rotted rear spring hangers and frame tails. made a new cross member,tails. got a spring hanger from vintagechevy.com
chas
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
04-26-2009, 10:35 PM | #3 |
The Older Generation
Re: Chassis
Most of the rust I have seen is in the area of the rear cross member (above the rear end housing) and the body mount brackets. Be sure and check the trailing arms if it has coil springs in the rear. The two halves of each one should be tight together with no separation or rust between them. If they have rust between them or rusted out areas along the inside channel they need to be repaired or replaced. I took a pair of them apart by drilling out the spot welds, removed all of the rust from between them and welded them back together. It worked out great.... LockDoc
04-26-2009, 10:44 PM | #4 |
Re: Chassis
I encountered the same problem with mine,rear crossmember ahead of the rearend where it meets the frame,aswell as between the 2 halves of the trailing arms.I split the arms and cut out the rust spots,welded in new steel,and bolted the arms back together.Also a little on the upper surfaces of the cabmounts.Blast away!Canada...72 chevy s/b 2wd.
04-26-2009, 10:52 PM | #5 |
Re: Chassis
he has a K10 with leaf springs.
04-26-2009, 10:54 PM | #6 |
its all about the +6 inches
Re: Chassis
basicly, once it is stripped, look for rot, or bends.
