Old 04-26-2009, 11:08 PM   #1
monte0185
monte0185's Avatar
Manual Tranny Question
I have a line on a sm465 Which i believe is a granny low tranny. What all is involved in changing one out? I currently have a 3 speed. The tranny is free by the way all i need is a shifter. I have a high hump floorboard section as well as If i remember correctly its gonna need.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-27-2009, 05:14 AM   #2
sea chief
Re: Manual Tranny Question
I just finished doing this myself. The 4-speed will bolt right in. You will either need a 4-speed drive shaft, or have yours changed because the slip joint on the 3-speed goes into the trans, while the 4-speed shaft has the joint in the shaft.
1967 K-20, 1969 K-20, 1970 C-30 dump,1971 K-20
1972 K-20, 1972 C-10, 1968 Grandprix
John Deere 350c Dozer, 3414 International backhoe
1972 International 1600 Flatbed
sea chief is offline   Reply With Quote
Old 04-27-2009, 08:52 AM   #3
monte0185
monte0185's Avatar
Did you use the same bellhousing? Do you have any pics? Did you shorten or lengthen the D-Shaft? The 465 looks shorter to me but i could be wrong. Sorry for all the questions I would just like to get all of this together before I do it.
I considered doing the nv4500 swap but this one is free and it will give me the pulling gears I want. Plus I just like a floor shifter. Gives me someplace to rest my hand. LOL
Old 04-27-2009, 06:09 PM   #4
Wrenchbender Ret
The 465 has a larger front brg. retainer. You will need a different bell housing.
Wrenchbender Ret is offline   Reply With Quote
Old 04-27-2009, 06:28 PM   #5
Old Bluey
Old Bluey's Avatar
I just removed my SM465, and it's heavy. 185lbs heavy. So keep that in mind when removing so the clutch isn't damaged while sliding it out or you're like me and crack the driveway.
The shifter on the trans is a funny one to remove if you haven't done it. The mounting "ball" needs to be pushed in a turned counter clockwise to remove. I piece of dowel should do the trick. You'll have to remove the long shifter before the install.
The output is usually a static yoke so you may need a completely different d-shaft to accomodate for the slip. The Transmission is shorter and I belive you'll need a "mid hump", but I may be incorrect. My truck did the swap from the 3 speed before I got it, and had a new hump installed.
You'll rarely use 1st gear, but it does come in handy from time to time. That trans can handle a 2 ton truck, so it'll feel really "torque-y"
Old Bluey is offline   Reply With Quote
Old 04-28-2009, 09:56 AM   #6
monte0185
monte0185's Avatar
This one dosent come with a shifter so Ill have to find one. Its sitting in a garage and i didnt see a bellhousing near by so ill have to check on that. I didnt really look real well either. Does anyone know if the starter will bolt to the bellhousing like mine currently does or will i need to put a block one on it? Does anyone have any pics of theirs?
Old 04-28-2009, 10:18 AM   #7
Old Bluey
Old Bluey's Avatar
Starter mounts to the bellhousing.
Great site for info:http://www.novak-adapt.com/knowledge/sm465.htm
Old 04-28-2009, 11:00 AM   #8
monte0185
monte0185's Avatar
Wow!! Lot of great info on that site. I appreciate it.
Old 04-28-2009, 11:48 AM   #9
heavy71chevy
heavy71chevy's Avatar
good luck on it
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 04-28-2009, 12:16 PM   #10
Green Machine
Green Machine's Avatar
67 and older used a 4 11/16 bearing retainer, 68 up used a 5 1/8 retainer size, just make sure they are both the same. Do not not put a tranny with a small retainer into a bell with a large hole, those parts work together to align everthing up and keep the trans centered.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-28-2009, 02:39 PM   #11
monte0185
monte0185's Avatar
Cool!! Glad to know that. Mental note!! Make sure all the holes are the same size!!
You know one could take that completely wrong now that I think about it !!!
Old 04-28-2009, 02:43 PM   #12
chadio72
Truck Enthusiast
chadio72's Avatar
i have two of those in the scrap pile now.free if u can pick up in merced, ca
chadio72 is offline   Reply With Quote
Old 04-28-2009, 02:53 PM   #13
monte0185
monte0185's Avatar
As much As i would like to come visit its a bit far from TN. Thanks though!!.
Old 04-28-2009, 02:55 PM   #14
chadio72
Truck Enthusiast
chadio72's Avatar
i also have a cpl of 203 tfr cases if anybodys interested local
