Old 12-27-2002, 12:18 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Question Lowering kits 2"/4" and clearance issues
Where is the best place to buy a lowering kit (2/4 drop with shocks)?. Will I have any clearance issues with my 275-60-15 tires on the front and rear?. Thanks.......Jim
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-27-2002, 01:09 AM   #2
BIG ORANGE
BIG ORANGE's Avatar
Thumbs up
www.earlyclassic.com I buy all my suspention stuff from them.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 12-27-2002, 11:38 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Got mine from Early Classic Enterprises, in California. I had to swap the front wheels (15x8) with their 255R70x15's, for a pair of 15x7's with a pair of 235R60x15's. I wanted 245's, but didn't find them when I needed them. I'm running 255-60's on the rear, but will probably go to 275-60's, in the near future, if I need to. My rear tires are 3-years old, an already have about 10K miles on them.
The conversion to disc brakes on the front will add about one inch to your front track, and may cause an interference with the tire to fender clearance. It just depends on the wheel offset and tire size. As for the rear, a 4-inch drop should not present any problems. Mine didn't, but I got the adjustable track bar to re-center the rear axle under the frame....and I got the shorter shocks, too.
Member Nr. 2770
