Old 04-27-2009, 09:26 AM   #1
terd ferguson
terd ferguson's Avatar
How to remove lower control arm shafts?
I had a buddy give me some lower control arms with the bumps stop brackets shaved off. They still have the original shaft in them. I'd like to swap the old shafts for new ones. How do you remove the shaft from the lower control arm?
Thanks in advance for the help.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 04-27-2009, 10:11 AM   #2
jason65
Registerd User
jason65's Avatar
Re: How to remove lower control arm shafts?
If its SLA like mine you just unscrew the end caps and slide it out. When you put them back in don't just tighten them down. They need to be adjusted. You can move the control arm foward or backward on the shaft. I just centered mine up.
jason65 is offline   Reply With Quote
Old 04-27-2009, 10:27 AM   #3
terd ferguson
That's what I thought. It just must be really stuck, lol. And thanks for the adjustment tip too.
Old 04-27-2009, 12:11 PM   #4
jason65
Registerd User
jason65's Avatar
I had to put a big a$$ wrench on it and kick the chet out of it.
Old 04-27-2009, 01:47 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
I took mine apart off the truck and my buddy and I used 3/4'' drive ratchet to take em apart. We were both standing on diferent ends trying to break it loose like this........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
