04-27-2009, 10:49 AM | #1 |
for you who run a 383 stroker
just wondering what you guys are running for a carb on your 383... just finished my build on a 383 4 bolt main with a mild cam and dart pro alum heads with large valves i got a desktop dyno that says i should be running 530 lbs ft of torque ... so what are u running 650? 700? 750? mechanical secondaries? vacuum secondaries? thanks for everyones help
04-27-2009, 12:40 PM | #2 |
Low & Fast!
Re: for you who run a 383 stroker
I would say 750 and buy a jet kit so you jet it for your likings..
04-27-2009, 12:59 PM | #3 |
Active Member
I'm currently running a AVS 800 on mine (I had it on the shelf and the 600 that was on it needed a rebuild) and I had to jet it down a bit to make it run right..
If i had a choice I'd run a 700-750...like tvblazer78 said...buy a 750 and a jet kit and tune it...
D.M.C -FF- |
04-28-2009, 10:19 AM | #4 |
On a budget like Fred Sanford
Edelbrock 1407 (750cfm) here, tuned with a wideband o2. Knocked down 17mpg on my last tank.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
04-28-2009, 10:42 AM | #5 |
chevy truck fan
i am the unusual one... iguess. i am running a holley 600cfm. i was told that it would help with getting more torque.
04-30-2009, 10:45 AM | #6 |
ya.. people have told me that if you want a low rpm torque motor to run a 650 but if you want to run 5 or 6 grand to run bigger like a 750 but idk i dont think my motor will last very long after anything over 4500-5000 because im running 11.0 compression ... everythings forged but idk what it can handel
04-30-2009, 12:06 PM | #7 |
I run an Edelbrock 750 and I'm running jets and metering rods at the richer end of the charts. It came very lean out of the box. It works well though.
Your redline RPM as far the bottom end is concerned is all about rotating assembly and fastener strength.
1977 GMC Sierra Grande |
04-30-2009, 01:12 PM | #8 |
US Army Veteran
I'm running an Edelbrock 1406 (600 CFM).
1972 C10 Highlander - The making of a daily driver |
04-30-2009, 01:15 PM | #9 |
I run an Edelbrock 1411 (750 cfm) that was jetted down while playing at the local 1/8th mile drag strip.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap -- '84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast |
