Platic or metal gas tank?
My metal tank needs replacing, should I go with metal or plastic? Thanks
Re: Platic or metal gas tank?
depends on what you like.. good and bad about both. Poly tank won't rust which is a plus... Metal tank is "like original" and could be undercoated...
50/50 for me so I went with aluminum, but that's was a truck conversion reason..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
The LuvShack Garage
I never cared for the way the straps fitted on my plastic, so I went metal on the other project.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
I replaced my OE tank with a PolyEthelane 'look-a-like' tank. Had to modify the filler as it is much much shorter than OE. It worked, after the first year I started getting a huge leak at the top were the sending unit o-ring seal is. It only leaked if I filled the tank.
The next year I replaced it with a 37gal NWMP tank, steel. It is a huge tank and I modified it to mount higher than it came from NWMP as it hangs kinda low.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
I think I will go with a metal tank, I think they cost about the same anyway. Thanks
I know the truckandcarshop from California had a kit at the last swapmeet I went to.. less than $200 I think..
![]() Join Date: Dec 2002
If you go metal which I did you will need someone to remove the old tank neck and put it on to the new, I say this only because we once had dozens of radiator repair places etc. I was lucky to find one guy who could do it. Most of those places atleast here were gone. Metal all the way
