04-27-2009, 08:21 PM | #1 |
how to remove bed?
Is there any how to threads on how to remove the bed? I want to make sure I done remove something I ain't suppose to... Thanks
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
04-27-2009, 08:36 PM | #2 |
Re: how to remove bed?
Short wide beds have 4 bolts, nuts on bottom of the bolt, bolts are flat on top and won't spin. There's a plug for the lights underneath on drivers side back by the gate. I have taken my bed off alone but they are heavy! More people the better.
04-27-2009, 08:37 PM | #3 |
Still livin the "dream" in '54
It's actually pretty easy. There are 8 bolts (well on mine anyway) and the nuts are under the bed. Well, nine if you count me under there as well.
Unplug the wiring harness from the taillights, there will be a master plug that disconnects everything and look for a grounding strap going from the bed to the frame. May be one there, may not be, just gotta look for it. Depending if you have rear tank, you will need to remove the bolts holding the filler neck to the bedside. Once you have all that... get 4 strong guys to help you lift it off. Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo Last edited by Richard8971; 04-27-2009 at 08:40 PM. |
04-27-2009, 08:48 PM | #4 | ||
04-27-2009, 08:48 PM | #5 |
longbed has 8 bolts, and unplug the wiring harness that is on the support behind the spare tire location on the drivers side. it really helps to have a lift to take it off, unless you got about 4 people. i used a chain hoist for mine, an engine hoist would do better. i had a board going across the bed under the bedrails hooked to the hoist in the middle. just jack up the bed and drive the truck our from under it.
rollin in my |
04-27-2009, 11:32 PM | #6 |
all i did on mine was undo the 8 bolts or should i say break off the 8 bolts.. unplug the wire then me and a buddy tipped it on its side then on its lid and called 3 or 4 more guys to help move it outside... it was hard to do.. make sure u got your eyes covered... bunch of stuff might rub off into your eyes
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
04-28-2009, 02:15 AM | #7 |
I really hate wet sanding!
C4
04-28-2009, 07:51 PM | #8 |
westofb C4 is for the FORD website you may scratch our patina (rust)
