04-27-2009, 09:25 PM | #1 |
When in doubt throttle out!!!
Seat Belt Bolt Removal
I have a C20 that I'm trying to add a center belt to and have torqued and torqued to get them loose and nothing. Am I missing something. Any help is appreciated.
Cheers |
04-27-2009, 09:47 PM | #2 |
Grandpa in the rustmobile...
Re: Seat Belt Bolt Removal
...well it LOOKS like to me (i never had it apart but would like to put center belt in..
thats its just a bolt, then the seatbelt, then the nut welded to the floor thing... somebody else will chime in that knows what there talkin bout lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-27-2009, 09:55 PM | #3 |
Yep. That's all it is. Just a square nut welded to the underside of the floor pan. The bolt then goes through it from the topside. Try crawling underneath the truck and spraying it with some PB Blaster. If that doesn't work, heat it up with a torch and then try it. (Make sure to remove any flammable objects from the area that you will be heating) 40+ years of road junk isn't too kind to the threads.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
04-27-2009, 10:00 PM | #4 |
and when you get them out its a really good idea to clean out the threads, some anti seize wouldnt hurt either
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
04-27-2009, 10:06 PM | #5 |
One of two problems...you have broke the nut on the underside of floor loose, or have stripped the threads and will have the bolt just pinning in the nut? Either way it is a Beotch to get the bolt out!!
04-27-2009, 11:10 PM | #6 |
The Red Menace
Those bolts have very short heads on them, it can be hard to get a grip on them with a socket or wrench. I put new belts in mine a few weeks ago, and it takes some work to get those things loose. I agree on the PB Blaster and some raps with a hammer to break things loose. Make sure to give the Blaster time to penetrate before trying again.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
04-27-2009, 11:27 PM | #7 |
Just the info I was looking for. Thanks all!
08-27-2009, 04:25 PM | #8 |
What size are the bolts - because I couldn't get a decent grip with my sockets and had to keep trying between 3/4 and 11/16ths - neither one would get enough coverage to get them loose at all.
When they come out - I will be replacing them with normal bolts where the heads are a bit larger... Since it is right under the gas tank - and I am removing the seat belts to remove the gas tank - there won't be any heat available to do this - Last edited by lks dcvn; 08-27-2009 at 04:26 PM. |
08-27-2009, 08:13 PM | #9 |
great im planning to install a center seatbelt and thought it was an easy pull..
the truck im pulling it from is 6ft in grass...looks like im waiting till winter no way im crawlin under that truck in that tall grass in summer lol
08-27-2009, 08:52 PM | #10 |
Project Junkie! Fishing Poor!!
The bolts are installed with glue on the threads so they won't back out. I use my impact gun to get them out. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 08-27-2009 at 08:52 PM. |
08-27-2009, 09:13 PM | #11 |
Watch out for your cornhole !
If you will get the weldnut nice and hot with a torch they come right out.
08-27-2009, 09:54 PM | #12 |
I just took mine out today...it takes a 13/16 socket
08-28-2009, 03:43 AM | #13 |
70 Chevrolet=Obsession
When I added shoulder harnesses I soaked the nuts with liquid wrench (the bottle not the spray) and I still couldn't get them off so I went to a local garage and they zipped them right off with an impact wrench. Didn't even charge me anything.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
08-28-2009, 04:58 AM | #14 |
Eat My Rust
Good socket and an impact wrench. And ear muffs possibly. I don't even think I had to use any lube with the air tools.
Viva la PSI |
