![]() Join Date: Dec 2008
Brake pedal question?
I am changing from a stick to an auto in the '69 Suburban..
How do you get the brake pedal assembly out? I took out the column, the two bolts on each side of the column, I unbolted the brake booster from the studs, I do not see any other fasteners...Is it just a really tight fit, or am I missing something? Tommorow I will get a little more forceful with it. Thanks for any advice? |
Re: Brake pedal question?
Found this pic (From Longhornman's post) that shows a bolt way up top, and out of view...that might be my problem?
Yes, that bolt needs to come out but there's no reason to take out the whole mount unless you just really want to clean/paint it. You can just unbolt the lever arm from the clutch linkage and remove the clutch pedal.
The whole Suburban is coming apart...Damn Codes inspector does not share my love of unloved vehicles....
