Old 04-27-2009, 10:27 PM   #1
slugish
Slugish
P s pump question & help
P S BELT SQUEALS > CAN'T GET IT TIGHT ENOUGH > IT SEEMS IT IS MISSING A LOWER BRACKET WHERE IT WILL SLIDE UP & back to tighten . Does there suppose to be 2 brackets foe the p s pump . Ionly have one & there is a empty bolt hole underneath . Just seems something else should be there to stabilize the pump & enable it to be tightened like it should be
Any help appreciated
some one else put it on when engine was rebuilt > suspect they didn't bother to hook everything up properly.
slugish is offline   Reply With Quote
Old 04-27-2009, 10:34 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: P s pump question & help
that sucks!
i had that same issue but the PO never re aligned everythign so my ps was liek 1/4in occ all the time and squealed..
the bottom bolt on your ps pump should also be a slider i just peiced mine together with a few washers and etc.. to make it work..
also to torgue the ps pump try not to pry it witha breaker it'll crack the resovoir (well i did)
instead use a crecent wrench and use the bracket itself...
good luck and i hope this was useful
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 04-28-2009, 08:10 PM   #3
slugish
Slugish
Originally Posted by dammitmitchell View Post
that sucks!
Thanks for your reply . Ithink the slider pc. for the bottom is missing on mine ?
Old 04-29-2009, 02:03 AM   #4
Rollie396
someday it will be done!
Rollie396's Avatar
year?pics?I know mine squeals every now and again,but it's because the pump is misaligned as was mentioned above.Just need to add a bigger spacer between the bracket and the head on mine.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 04-29-2009, 09:04 AM   #5
dammitmitchell
the pollock
yeah dude might wanna post a picture.. or go to the junk yard and grab a new bracket...
(iffin your is actually missing parts)
Army vet 02-08
Old 04-29-2009, 08:57 PM   #6
slugish
Slugish
yea , need to go to bone yard & look at others .
thanks for the reply. Still don't know how to post damn pic's on this site . My son has done it for me before . Need to learn myself!
