Old 04-27-2009, 10:32 PM   #1
dan42
dan42's Avatar
window and track question -
Does anyone know where the window is supposed to be postioned in the base? When I took them out, they were in a little different position on both sides, but there was no felts left, so it didn't matter. Now that everything is gonna be good and tight, I need to know where it's suppose to be. Do you just center it, similar to my picture?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-27-2009, 10:56 PM   #2
72BLUZ
72BLUZ's Avatar
Re: window and track question -
how you have yours marked is how mine was done
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 04-28-2009, 12:43 AM   #3
dan42
dan42's Avatar
I'm thinking that if I center it I should be O.K.. I just don't want to get it together and find that the window is too far one way or the other.
Philippians 4: 6-7
Old 04-28-2009, 08:14 AM   #4
chevy72pu
chevy72pu's Avatar
Are you putting the original glass back in? If so, what you have marked should work. I used replacement glass from Brothers. Drivers side went in fine. Passenger side glass shape was a little off. I wound up notching the bracket that holds the inner and outer door skins together, in order to get the glass in. Only took 1/4" notch but it wouldn't go back in the track without it. Trial fitting is the key. Keep adjusting til you get it right.
chevy72pu is offline   Reply With Quote
Old 04-28-2009, 09:14 AM   #5
monte0185
monte0185's Avatar
Sorry to hijack but I have a question that pertains to this. What goes in between the glass and the metal bracket? Is it glued in or what?
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-28-2009, 09:43 AM   #6
dan42
dan42's Avatar
There is a piece a rubber-like material that you can get at an auto glass shop - they have different thicknesses, and if you have a piece of the old one, take it down with you to get the right one.
Philippians 4: 6-7
Old 04-28-2009, 09:59 AM   #7
monte0185
monte0185's Avatar
Cool thanks!!
My metal pieces are rusted in my doors but the doors im getting have good metal pieces but broken glass. So I gotta take the two and make one decent set of doors. Good luck with your and I appreciate the help.
