Old 04-28-2009, 12:58 PM   #1
ChicoSmith
When in doubt throttle out!!!
ChicoSmith's Avatar
Question Pully Wobble Problems?
I have a C20 with a 327 AC/ALT/PS Pulley system that seems to have a little play or whobble. On a red light idle I sometime hear the tink tink of the fan touching something.
I just replaced the water pump and fan clutch about a month ago. Recently threw the AC belt (from the whobble?)
Can anyone help me troubleshoot the cause or direct problem of this? Is it possible that the water pump shaft is already spunked or is a little movement here normal?
ChicoSmith is offline   Reply With Quote
Old 04-28-2009, 01:44 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Pully Wobble Problems?
Did it also do this before you changed the water pump?
If not, my guess is that it is a bent water pump shaft. It could also be a bent pulley.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-28-2009, 06:08 PM   #3
69GMCLonghorn
69GMCLonghorn's Avatar
Sounds like a cracked crank shaft to me... This would be a great time to drop in a BLOWN 502!! I hear they have never experienced a pulley problem to this day! HAHA
69GMCLonghorn is offline   Reply With Quote
Old 04-28-2009, 06:14 PM   #4
john
member #16
john's Avatar
Have you checked the motor mounts? Possible cause of tink tink fan noise.
john is offline   Reply With Quote
Old 04-28-2009, 06:14 PM   #5
DANTIP
DANTIP's Avatar
I would try to watch the belts/pulleys as the throttle is opened and closed. You may be able to zero in on the problem. I diagnosed a bent pulley earlier today with this method.
Good Luck!!
DANTIP is offline   Reply With Quote
Old 04-28-2009, 06:18 PM   #6
ChicoSmith
ChicoSmith's Avatar
Thanks guys for the quick responses, hopefully its not the crankshaft. That 502 would be nice.
I will try taking a better look under idle and see what happens with some throttle...
Thanks again.
