Old 04-28-2009, 01:17 PM   #1
bmfpeterson
bmfpeterson's Avatar
Air Bags or coils???
I want to do a 5-7 drop on my 71 with trialing arms.
What can I expect ot pay for a set of bags and brackets for the back?
I know you can go all out with air but I just want a nice ride so switches are out
Would it be worth it to just do springs and spindles in the front with bags in the back?
Thanks for your help...
bmfpeterson is offline   Reply With Quote
Old 04-28-2009, 01:21 PM   #2
bmfpeterson
Re: Air Bags or coils???
also.... how much do i need to c-notch? or how much can I go before i cut into my bed???
any suggestions on a weld in c-notch?
Old 04-28-2009, 02:52 PM   #3
SCOTI
SCOTI's Avatar
A bolt-in c-notch is as far as you can go before the pumpkin hits the bed-floor. So unless you plan on cutting the floor out, there's no need for a weld-in style kit on a 7" rear drop.
On a budget, the static front + bagged rear works very well. Bags will run you about $75ea & if you drill the frame, you don't need brackets. You will need a 1.5-2" lowering block to maintain decent bag pressure for a better ride & to help w/the shock travel @ 7" of drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-28-2009, 11:47 PM   #4
bmfpeterson
Sweet! So as far as drilling the frame--- You cant just use the holes for the coil spring bolt? I have seen guys do a plate welded to the trailing arm to match the bag diameter is that not necessary or I'm I way off??
Thanks for the help
Old 04-29-2009, 12:08 AM   #5
bmfpeterson
I just saw a write up on rear bag install...now I get it.. Thanks for the help
