04-28-2009, 03:09 PM | #1 |
Self Made Hundredaire
Save these pics!!!
Why you should not heat your rear coils unless you know what the heck you are doing/ shouldn't do it at all. I kind of hate my p.o. right now...
pass. side drivers side
'79 corvette - all original 49k car! '03 Z71 ECSB - gas hog '57 Belair 2 door hardtop. Love of my life! |
04-28-2009, 03:23 PM | #2 |
Gearhead
Re: Save these pics!!!
Holy crap that looks scary! Please dont drive it that way!
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
04-28-2009, 03:51 PM | #3 |
I won't be. I'm still trying to get it running right now, but I will need a nice set of springs before it moves.
04-28-2009, 04:04 PM | #4 |
How low do you guys think it is now, I wanna know what drop springs i need to get it back to the same height.
Those are 275/60 and 215/65, rear and front
04-28-2009, 04:13 PM | #5 |
Looks like 4" springs is what you will need (you have a block in there that looks to be a 2")
I can't figure out how your rearend is mounted... Where is the u-bolt that goes over the axle??? Is it going in from the bottom? I don't like whatever is going on with it...
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
04-28-2009, 04:40 PM | #6 |
Do I need glasses or did the P.O. also flip the U bolt and just tighten down the saddle??
04-28-2009, 04:42 PM | #7 |
Gearhead
Yeah I didnt even notice that, the U-bolt is upside down!!! I didnt even know you be that creative I think I would take out the hollow blocks and use a 6" drop spring or put some bags in there and use new U-bolts installed correctly.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 Last edited by 6772owner; 04-28-2009 at 04:44 PM. Reason: text |
04-28-2009, 04:43 PM | #8 |
it is atleast 5" like mine or it might be a little lower maybe 6"? but definately more than 4"...
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
04-28-2009, 04:58 PM | #9 |
I didn't even notice that. holy crap. Ima go slap somebody in the face. wow. I'm pretty much dumbfounded.
04-28-2009, 05:26 PM | #10 |
Gearhead
Yes I was amazed, my mouth dropped too. Hope you can turn that around when you redo the drop the correct way.
04-28-2009, 05:36 PM | #11 |
so which does everybody think is the best way...
4" drop springs with those blocks, 6" drop springs, no blocks, or bags, which i really don't have the money for, unless someone is selling a rear setup fairly cheap. also, what is the easiest way to do a c notch w/o a welder readily available?
04-28-2009, 05:49 PM | #12 |
Gearhead
You can get Airlift Dominator D2600 Bags for about $85/each I would say 6" springs and ditch the blocks personally.
04-28-2009, 07:55 PM | #13 |
Texas Big Wig
You can get bolt in C-notches that will give you 2-1/4" more clearance IIRC
If you decide to run bags, I would definately run Slam Specialties RE-6's in the rear If you stay with springs, I would prolly get the 6" drops & ditch the blocks |
04-28-2009, 09:59 PM | #14 |
4" springs or bags w/the blocks (they allow for more drop w/o any ill effects on shock travel).
04-29-2009, 01:07 AM | #15 |
Commander Taco Bello
bags!
04-29-2009, 10:24 AM | #16 | |
With the 6" spring you get a heck of an angle on the shocks unless you get shock relocators. Rg
04-29-2009, 04:45 PM | #17 |
I would really love to have bags, but I just don't think they are within my price range at this point. What would I be looking at for a decent setup for the rear, which I could add onto later for the fronts?
