Old 04-28-2009, 03:31 PM   #1
souza777
souza777's Avatar
76 to a 79 grille?
what would I need to change if I want to go from a 1976 grille to 1979 with round headlamps?
Also how do I get a picture to come under my name for the forums??
souza777 is offline   Reply With Quote
Old 04-28-2009, 04:15 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: 76 to a 79 grille?
it will be easy if the hood release are in same place either in the cab or grille
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-28-2009, 04:56 PM   #3
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
76 has offset hood release, 79 has in center iirc, never owned a 79 or 80, well i own a 79 but just dont pay attention to it. But 76 has the offset handle so it will require different grille than the 79 IIRC.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 04-28-2009, 05:23 PM   #4
boatpuller
boatpuller's Avatar
go into user cp when your logged in and then edit avatar.and upload your pic.
also,the 79 grill has a upper and lower stainless trim strips and bezels that incorporate the turn signal if your planning on going that far.here's a pic where you can see some of it.everything on the front is stock other than the billet grill.the hood is also different,i'm not sure what years had the raised flat front like you see on mine.79,80?
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 04-28-2009, 06:19 PM   #5
souza777
souza777's Avatar
where's your hood latch release?
Old 04-28-2009, 06:31 PM   #6
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
My '80 didn't have that "raised" area on the front of the hood....but it was a plain-jane truck with the round lights.
My '78 has the remote hood release and '79-80 Grill trim. Grill swaps are pretty straight forward, may need some slight latch reworking, but no big deal.
69BBsuburban is offline   Reply With Quote
Old 04-28-2009, 07:48 PM   #7
boatpuller
boatpuller's Avatar
remote...inside pull lever
Old 04-29-2009, 04:04 PM   #8
Dooley
Dooley's Avatar
The trim line across the front of the hood began in 1979. The stainless trim parts above and below the grille are not attached to the stock grille so you can use your stock headlight bezels. The inside hood release was an option until 1980. I ordered the one on my 79.
Second pic is of my stock 1979 Silverado.
Dooley is offline   Reply With Quote
Old 04-29-2009, 09:09 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Interior hood release option started in 1977.
Hood latches are broken down like this
73-74
75-76 (this is the one that is offset)
77-80
You need the latch assembly from the 75-76 if you are going to use the hood. You can make the 76 fit with some modification though.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
