Old 04-29-2009, 12:12 AM   #1
highperf4x4
A/C controls
The top lever for my A/C controls is broken. Has anyone replaced just the levers? The rest of the unit is in pretty good condition and I know I can buy the levers seperately but I'm not sure how much trouble it is.
highperf4x4 is offline   Reply With Quote
Old 04-29-2009, 05:10 AM   #2
JimKshortstep4x4
Re: A/C controls
If you have the control out where you can get at it then it is not too bad of a job. I use a pair of needle nose pliers behind the knob as something to hit against to remove the knob as they are pressed on.
Otherwise it is pretty straight forward to replace the lever.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-29-2009, 10:31 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Re: A/C controls
I did a complete rebuild on one here:
http://67-72chevytrucks.com/vboard/s...d.php?t=245558
I obviously went way farther than you'll need to. I took the face off and everything.
One thing you will have to do (which I show) is that once you pop the small plate the holds the arms on (the metal is "riveted" around the plate) you'll have to figure out a way to put it back on. I carefully drilled holes and used screws. Other than that, it should be fairly simple.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-29-2009, 12:09 PM   #4
highperf4x4
Re: A/C controls
Could that plate just be riveted again?
Old 04-29-2009, 12:34 PM   #5
highperf4x4
Re: A/C controls
That's alot of good information, thx!!
