12-27-2002, 03:26 PM | #1 |
What rearend are you running
Im getting close to the point of working on my rearend and was wondering what others are running with higher horse applications. Beefed up 12 bolt truck, 9 inch Ford, Dana 60 or others. Concerned about c-clips and hear c-clip eliminators leak. Im running a early classics 4/6 drop so I dont have to worry about the panhard (trackbar) mount on the axle housing. Has anyone found another application the right length ?
Mark 72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction 05' GMC Sierra Denali LQ9 |
12-27-2002, 03:28 PM | #2 |
Almost Satisfied
I am using the 4/6 drop with my stock 12bolt and a new 3.73 Ring and Pinion/Eaton Posi unit. I plan on having around 400hp when the motor is finally bought. From what I have read and from the conversations with local shops the 12bolt is great for street use and this kind of HP.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
12-27-2002, 03:40 PM | #3 |
Fabricate till you "puke"
12 bolt, with eaton posi/4.10 Richmond gears. i am running in the 400hp range with my 383(street driven). I dont think you will have to worry about braking it, unless you are running slicks& really hooking up hard. I have been told that the C clip eliminators are not the best for street use(they tend to be leak prone), & need a lot of maintainance.
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-27-2002, 08:12 PM | #4 |
Used to have a truck
Dana 60's are readily available in junkyards with performance ratios and with lockers or posi units. Axles can be made to any length . After that its just a matter of having the tubes cut and new ends welded on that accept your brake hardware. Ive built quite a few from boneyard Dana 60's that I didnt have more than $500 in by the time they were done with new hi strength axles , posi units and 4.11 gears. No c clips to worry about either.
No truck :-( |
12-28-2002, 12:58 AM | #5 |
Crazy Longhorn and 1971 Stepside are you both happy with the Eaton Posi ?
12-28-2002, 05:49 AM | #6 |
Corp. 10 bolt HO72 w/ 3.90s and Detroit Locker. Rebuilt last year.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
12-28-2002, 08:46 AM | #7 |
I dont have any complaints on the eaton unit, mine came from a 73 12 bolt that I swapped a tilt column for. The unit got new plates & springs before I installed it in my truck, so I saved a few bucks going used & doing the labor......
12-28-2002, 04:17 PM | #8 |
72 Cheyenne
I'm guessing around 350 HP, Dana 60 with Dana Spicer 3.54
12-28-2002, 04:34 PM | #9 |
Any recommendations on board members or prefered rebuilder for rearends ? Preferably in the southeast. I want to change ratios (around 3.73) and add a posi.
