ride height
I purchased a '88 GMC pickup 1/2 ton 2wd with a 454 in it. The truck had lowering a-arms on it. I removed these and put stock a-arms on it. I then found out that the coil springs had been cut also. I replaced these from a junk yard. My height seems kinda high now. I have 33" from the ground to the bottom of the fender. Is this the correct height? Does someone have a late model they can measure and let me know if this is the correct height? I'm in the process of having a 350cid built to put in the truck and I know the weight is gonna make a difference when I do this. May have more clearance then because of the weight difference. Thanks for the input..
Happy to be here
![]() Join Date: Mar 2000
Re: ride height
Anyone?
![]() Join Date: Apr 2009
Re: ride height
I measured 32" on my 86 c10 for the high point of both the front and rear wheel well. All my parts are stock for suspension and I think its about time for some new suspension as it drives like a warthog (really cheap jeep) on HALO (computer game). The fender by the bumper read 15". I hope this helps. Let me know if you plan to sell the 454. I would like to upgrade from my 305 v8 to a bigger engine and transmission. ^o^
#4 | |
Re: ride height
#5 | |
Re: ride height
Re: ride height
I'll have to check around and see what BBC are going for. I have no idea. Does anybody know? I'm thinking the motor is out of a early '90 model 3500.
Re: ride height
Sorry... I don't think I know what a BBC is... >.> I'm assuming it is a big block carburetor? I found some I like on ebay and jegs. I don't know what your budget is but jcwhitney and amazon have some. It might just be the difference between a square and spread bore carburetor as opposed to 2 and 4 barrel. I hope this helps.
Re: ride height
BBC = Big Block Chevy
Re: ride height
Ah. Now I understand. One day I'll know the lingo. Lol. I think craigslist, google, and ebay would have a good ball park answer and the junkyard could maybe quote a working overhead. I tend to think that junkyards are expensive around me though.... The junkyards in Houston are much cheaper.
