4-6 drop
I've got a 71 swb fleet coil spring truck. If I go with a 4-6 drop from early classic - 2.5" spindles, 1.5" front spring, 6" rear spring, with the adjustable bar and shock relocate kit will there be any other clearance issues.
I already have the front disks, and I already have the correct 15" wheel/tire combo. I am just wondering about bed clearance and any other issues in the front. I slammed a 90 chevy once and had to quite a bit of cutting under the truck. |
Carolina Classic Trucks
sent you a PM
Member since 2000
you'll be fine, would not hurt if you added a c-notch but i put a 4/6 ECE drop kit on two truck wiht out the c-notch and no problem here.
Almost Satisfied
![]() Join Date: Mar 2002
with the 4/6 you will have no trouble with clearance. ECE makes some great stuff too.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
I have one on mine and it's just fine, but would it still be alright with 18" rims?
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!! |
thanks everybody, I am looking forward to doing the drop. Will I still be able to pull anything, will I still be able to haul anything. How does the ride feel. I would love to put some 18"s on it someday, I imagine with the correct backspacing they would fit fine.
How about that, a fellow New Mexican. What part are you from?
Member since 2000
18 would fit fine, i'm dropping 20's on my blazer.
I'm from Farmington, been here most of my life. I only get to ABQ a couple of times a year.
