SWB frame
This is a question for all you Guru's out there. A guy that works for me asked a question I can't answer so I'll run it by all of you. Is a Swb and a blazer frame the same? He found a good blazer frame and wanted to use it for his SWB 70 model that he is building.
Thanks RRM
1969 C10 SWB 350 W/700R4 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: SWB frame
Nope, Blazer frame is significantly shorter.
dazed and confused
Re: SWB frame
yep what he said
members met: redbaron69, billsbowtie,nc67 |
![]() Join Date: Apr 2005
Re: SWB frame
SWB = 115" wheel base
Blazer = 104" wheel base http://67-72chevytrucks.com/vboard/s...d.php?t=322396
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: SWB frame
It would make a cool shortie flatbed.
Re: SWB frame
Appreciate the info. I will let him know.
RRM
Re: SWB frame
I have a 72 blazer frame with the cab and bed from a 72 K 10 . The bed was cut down 11 inches. Very sporty short bed. They kept both the under the bed and behind the seat gas tank.
