12-27-2002, 03:59 PM | #1 |
Need drop springs and centerlink
Went to get front aligned today after doing disc brake swap.
Turns out, (I didnt' notice, as I did the swap on the ground in the COLD), front is riding on the bump stops due to the wrong springs. Springs aren't even seated in cups. Rear has been heated for drop. I have had the truck ~8months, so still learning what somebody else managed to muck up. So before I can align it, I need new springs, front and rear...as well as a new disc brake centerlink, as I believe the drum is diff. Looking for new springs. Want to buy from a vendor who visits here. So shoot me email ty1295@insightbb.com Need 2" front/4" rear... all coil springs. I just spend a ton on this truck, so don't want to step up to spindles yet. I do not think the 2" spring should be issue, but correct me if I am wrong. Also needing the centerlink, unless it is same, again correct me here.
Jeff Scott '70 GMC Stepside, Short box '63 Nova '92 GMC typhoon '95 Tahoe |
12-27-2002, 04:19 PM | #2 |
Carolina Classic Trucks
You have mail.
