04-29-2009, 10:00 AM | #1 |
Rear Disc Brakes for 72 Jimmy?
Hey Guys.
I have power brakes and front discs on my 72 Jimmy right now, but i would really like some rear disc brakes as well. Whats the best way to go about this? Should I Get a disc conversion or is there a certain rearend with discs already that i can swap out? |
04-30-2009, 08:14 AM | #2 |
Happy to be here
Re: Rear Disc Brakes for 72 Jimmy?
It really depends on what your after. There are several of our forum vendors that offer rear disc conversions. Some have a complete systems.
There are others who have the brackets required to mount the calipers, allowing you to build your own.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 05-07-2009 at 08:23 AM. |
04-30-2009, 09:45 AM | #3 |
Hmm a conversion may be good. Which vendors offer them? I'm going to look at the vendor list now but a point in the right direction would be sweet!
05-03-2009, 11:13 AM | #4 |
i'd prefer to swap in the parts from a late model gm truck rather than go with aftermarket.....more straight forward for replacement parts.
only problem is that chevy only had rear disc for 6 lug and 8 lug vehicles. 2wd is 6 lug from 2000 and up. i may some day just graft in the entire rear axle from a late model truck into my 72 3/4 ton 2wd suburban. better parts all around and a nice limited slip option! |
05-06-2009, 08:52 AM | #5 |
Hmm. I found a kit from CPP that runs about 500$.
Ive heard good things about them, im thinking about going with that. Sound promising? |
05-07-2009, 12:53 AM | #6 |
what rear end do you have? 10 or 12 bolt? On my Chevy Nova what I did was take a 10 bolt rear end with disk brakes off of a 99 Z28 and took the brakes off of it and put them on my Nova rear end. Bolts right up!! The only mod I had to do was make and weld on an emergency brake cable bracket... took like 20 min. No joke that easy. I got the whole rear end for $200 and got disk on my Nova, sold the rest of the rear and made $75 back.
Take that you expensive kit!! LOL. |
05-07-2009, 03:32 PM | #7 |
You should look into the mid 90s impala/caprice. Disk brakes, limited slip and I read somewhere they are pretty close to stock width. They also have a 5x5" bolt pattern. Camaro/trans am rear ends are pretty small for a full size truck, not to mention the 5x4.75" pattern. Ford 8.8"s are also not bad, some have disk brakes and limited slip. These things are a dime a dozen. Get some new axles and your good. Youll still spend less going this way.
05-07-2009, 11:37 PM | #8 |
Hey guys,
I broke down and just got the CPP kit for $599. Install will be coming shortly....... |
