Grade 8 bolts and rust
How rust resistant are grade 8 bolts when used on the frame?
Re: Grade 8 bolts and rust
No more resistant than any other steel based fastener.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
The hardness of the bolt does not have anything to do with rust resistance. If you are looking for nuts and bolts with good rust resistance, then you should be looking for coated nuts and bolts. Like zink, cadium, black phosphate, and etc. Zink coated nuts and bolts will give you plenty of rust protection. My personal preferance for the hardness for frame work is grade 5 though. They are not as brittle and offer just a bit more flexabillity. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
its all about the +6 inches
Wes, I think you and I are the only ones who do that on here.
The grade or strength of bolt should be in direct relation to where you intend to use it.
Outside of the suspension you probably don't need grade 8. I used to install a lot of trailer hitches on cars at a dealership in the 70's and they were shipped from the factory with grade 2 bolts. I'm with Wes and Longhornman in that a good grade 5 with good plating is fine in most cases. In years of buying fasteners for automotive and industrial use I always felt that I was better off buying a product that the maker put their mark on so you could tell who made it. I have always been a bit shy of grade 5 bolts with no mfg marking. |
if you're worried about rusty bolts either go stainless or paint the plain steel ones
#7 | |
Middle-aged Curmudgeon
I never use anything tougher than grade 5. I used to work at an outfit that built tow trucks. They did extensive frame stretching, including making huge tow rigs out of semi tractors. They never used anything harder than grade 5 in their frame lengthening operations, or anywhere else on the truck for that matter. I've never been too impressed with the rust resistance of the zinc coated stuff. Only lasts a year or two for me then it's as rusty as anything else. The black phosphate coatings looks great, but I don't know how long it lasts. Anyone know?
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 Last edited by Lugnut64052; 04-29-2009 at 04:32 PM. |
Nothing to see here.....
![]() Join Date: Jun 2007
black phospate will last longer, but that also depends on the length of time it originally spent in the solution.
hardware that has been well covered and penetrated deeply with black phosphate should withstand years without oxidation. I have never been to keen on zinc coatings. heat and abrasive environments can take that stuff off el quicko......
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 04-29-2009 at 05:21 PM. |
I am a Referee of life.
If you really want rust sesistance you need to use stainlesss.Contrary to popular beleif stainless will rust and must be anti-siezed before installation.I personally use a lot of stainless at work but would only use them as polished on exposed engine fasteners on a truck.
I think the others have steered you right.I also would only use grade 5 on suspension parts.I would much rather have a stretched grade 5 holding it together than a broken grade 8 not.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
^^ yep, 400 series stainless will and does rust. 300 series will not.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
![]() Join Date: Dec 2008
rust (oxidizing) needs to things, oxygen and water, paint it, keep it dry and your bolts will be fine....as far as grade goes. an SAE Grade 5 may be strong enough,but in reality that is an engineering question, refer to a book like a Mark's engineering handbook, or use a comparable factory fastener...or ask A Mechanical Engineer. I have an opinion, but will respectfully not give it.
Hello all,
I am a mechanical engineer and do stress analysis for sizing bolts periodically. Contrary to some beliefs, grade 8 bolts are far superior to grade 5 bolts in all aspects of stress and strain. Here is good link explaining this. http://www.rockcrawler.com/techrepor...ners/index.asp
Randy, West TN 67 Fleetside SWB L6 3 speed on column 84 Feetside SWB L6 3 speed on column yes, I like column shifts 99 Dodge 4X4 Ext. Cab |
#13 |
Eat My Rust
If you have a GM dealership near you, and have good relations with one, see if the service department will sell you their Grade 8 bolts. Their required to carry standard thread bolts, but all modern GM vehicles use metric. So they have a big inventory of useless bolts...
#14 | |
#15 |
I checked back in on this thread. Thanks for all the information. I learned a lot more than I asked for.
