04-29-2009, 10:58 AM | #1 |
dazed and confused
spindle problem
i have the new modular spindle from classic perfomance. how much clearence should there be were the tie rod end and the wheel. it is not hitting but it is real close, i dont think a wheel weight would clear. and know you like pictures so here is one of the truck when i started on it a while back. thanks
members met: redbaron69, billsbowtie,nc67 |
04-29-2009, 11:13 AM | #2 |
Son of a gun
Re: spindle problem
Do your wheels have a custom backspacing?
Bill BEATERS ARE NEATER |
04-29-2009, 11:18 AM | #3 |
Re: spindle problem
Are you useing 15inch wheels?Some of those have clearance issues.You could try stick on weights.
04-29-2009, 12:22 PM | #4 |
Out of the carpool lane.
Re: spindle problem
That spacing is not unusual and like mentioned above, you might need to use stick on weights instead.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
04-29-2009, 12:31 PM | #5 |
Nothing to see here.....
Re: spindle problem
As Brad stated, that is completely nomal. some have even had to grind the tie rod head a bit. going with stick on weights is a must.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
04-29-2009, 01:31 PM | #6 |
dazed and confused
Re: spindle problem
cool. i had thought about grinding the end of that it is preety solid. the wheels are wheel vintique 15x8 ralleys. no special offset. the springs are a 3 inch drop i think. thanks for the answers guys. i love this place.
04-29-2009, 02:39 PM | #7 |
resident oilfield trash
Re: spindle problem
When I first put my spindles on I couldnt figure out why my wheel would roll half way around and stop. There is little to no clearance between the tie rod end and my wheel
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
04-29-2009, 04:50 PM | #8 |
dazed and confused
Re: spindle problem
that is what happened to me!
04-29-2009, 05:36 PM | #9 |
sharp as a marble
Re: spindle problem
I would love a couple of pictures. I am planning to use those for my Blazer. What is your opinion of the product, and are there any other issues. I am also planning to go to 17" wheels, so I would assume that the tie rod/wheel clearance issue would not be there. Do these spindle really tuck the tires under the truck 1" per side as advertised?
04-29-2009, 06:52 PM | #10 |
dazed and confused
Re: spindle problem
i will take some. so far everything is going on good. i have not had any issues that you wouldnt have switiching a drum brake truck over to disc. i got one side done and does tuck the wheel good. you can tell that it is sitting farther back. i will make sure to get some measurments when i go out there to take the pictures.
04-29-2009, 07:14 PM | #11 |
Re: spindle problem
If you are using a 3" drop spindle with the stock steel rallys they will rub on the lower control arm also. I have found if you want to stay with a steel wheel only use 2.5" drop spindles this will prevent rubbing issues. 17" wheels will cure it with the correct backspacing or stock backspacing.
