Drum / Disc Swap
I have a '68 gmc half ton that i'm converting to 5-lug. I've already converted the rear to 5-lug and i'm getting ready for the front. I've heard that i might run into clearance problems with my lower control arm. I'm putting '72 chevy front brakes on it and i'm wanting to install 3" drop spindles. Guess i'm asking is there anything to be look out for when i start in a couple of weeks. Thanks.
Grandpa in the rustmobile...
Re: Drum / Disc Swap
i think with 3 inch spindles and 15 wheels can rub...might wanna go with 2.5 or bigger wheels...this is just wat ive heard
i got all the stuff to do it just scared to..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Always wrenching!!
I heard with a good size drop that the inner rim will rub on the control arm.....
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
I've got a set of 15's for the truck. They were on the '72 when i bought them. I'm using them cause i've got a set of 1970's gmc hub caps. Just wonder if i go with a 2.5 drop spindles. I've already cut the coils in front about 12 years ago. Just wanting moe of a drop.
Just as the others say. If using 15" steel wheels, stay with a 2 1/2" drop spindle. If using a 3" drop spindle, the rim will rub on the lower control arm at the lower ball joint boss. I have run into this with Belltechs on a freinds 72.
Thanks For The Info.
