Old 04-29-2009, 09:15 PM   #1
Bullseye54
Short-step bed weight
I have a 68' gmc short-step that I swaped to truck arm suspension & did a 4/6 drop on,along with 4 wheel discs swap.I'm trying to set everything up as far as ride height & see if I need to notch the frame,without putting on the bed.I want to add the right amount of weight to the rear frame.Does anyone have a rough idea on the bed weight?...........................Bob
1967 C20 Custom - 396/TH400
1968 GMC short step-350/M21
Bullseye54 is offline   Reply With Quote
Old 04-30-2009, 06:28 AM   #2
Bullseye54
Re: Short-step bed weight
Anyone with an estimate on the wgt.................Bob
Old 04-30-2009, 05:09 PM   #3
Sammy
I'll stab a guess @ 250 lbs with bed wood and tail gate maybe slightly less.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-01-2009, 08:36 AM   #4
Bullseye54
Thanks,I was thinking between 250-300.......Bob
