Old 04-29-2009, 10:46 PM   #1
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Are stock front springs worth saving?
Hi guys,
Finally getting around to doing the front suspension. I have a bare frame (no cab, engine, tranny, etc.) so there is no weight on the front. I have all the steering parts off and got the ball joints popped loose but still held on with the nuts. Since I typically have done these swaps with the engine still in, I can't jack up the lower arm to take the spring tension off the nuts. The whole frame lifts up.
I can heat the coils and let them compress to take the tension out of them but are they worth saving for any reason? If they are not, I'll heat them, if they are, I'll come up with a way to compress them.
Thanks!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-29-2009, 11:26 PM   #2
AlienYouth
AlienYouth's Avatar
Re: Are stock front springs worth saving?
spring compressor?.... just a thought
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 04-29-2009, 11:33 PM   #3
BATurbo
BATurbo's Avatar
Do you know if the springs are the originals? If they are, then it probably couldn't hurt. I am running the springs that were in the truck when I bought it back in 1990. I'm guessing they may be the originals, but I don't know. I have talked with a local spring company rep and he of course said they should be replaced. I haven't heard of many coil spring failures, not to say it can't or hasn't happened, but if the ride height is correct and the springs aren't rusted, cracked, or sagging, then I doubt you'd have much trouble. I am a fan of "if it's already torn apart, you may as well change them out", but in the current economic times, you could probably get away with running them.
BATurbo is offline   Reply With Quote
Old 04-30-2009, 10:32 AM   #4
chevy_mike
chevy_mike's Avatar
Springs are original and from what I could tell, not sagged based on ride height. I have the ECE front springs, spindle, disc, etc. for the front end so I have no interest in keeping these springs.
I could use a spring compressor but I only have an external version. I could go a loaner but I have the torch at home so I wouldn't have to mess with picking up and returning the compressor.
I just don't know if there is any value in the original stock springs, front and rear (rears are already out).
Old 04-30-2009, 12:33 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just put a few hundred pounds on the frame up front. a couple average sized guys will do the trick.
Or, chain up the coil, and let it fly. It ain't goin far chainged up.
These aren't like gas charged McPherson struts.
Old 04-30-2009, 01:52 PM   #6
my67chevytruck
Under Construction
my67chevytruck's Avatar
I went through the exact same scenario a few months back, and even with a couple hundred lbs (son and nephew) sitting on the fram still wouldnt compress enough. I put the fram on jack stands, chained the coil to the frame and went from there
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-30-2009, 02:59 PM   #7
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
you should keep them... you never know. Just my $.02
LOW DOUGH is offline   Reply With Quote
Old 04-30-2009, 04:37 PM   #8
nsuengineer06
nsuengineer06's Avatar
I may just be crazy or something, but when I took my front coils out, I had the entire cross-member out of the frame sitting on the floor and I just knocked the ball joints loose.. It makes a little racket and jumps pretty good but never had a problem doing it that way.. lol
1967 C10 LWB 454/TH400
1971 C10 SWB
1984 C30 LWB Dually 454/4 spd 4:10
2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison
nsuengineer06 is offline   Reply With Quote
Old 04-30-2009, 09:00 PM   #9
Neal Molder
The Black Pearl
I also ran into this problem a few months ago. I used large welding screw clamps i had kicking around. Springs compressed no problem!
Neal Molder is offline   Reply With Quote
Old 05-01-2009, 11:16 AM   #10
chevy_mike
chevy_mike's Avatar
Well, I borrowed a compressor from a friend so tomorrow I will do it the right way. Thanks for the opinions.
