Old 04-29-2009, 10:53 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
Unhappy think i broke my ps..
seriously i had too much fun this week with my truck...
when sitting (or moving slowly) the PS feels "jerky"...
going to lift up the frint end this weekend and check the PS components..
any reccomendations?
might take off the motor itself and see if it's trashed inside..
any ideas?
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 04-29-2009, 11:39 PM   #2
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
Re: think i broke my ps..
hey man check that out for me too my trucks done that since i got it
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 04-30-2009, 12:04 AM   #3
Longhorn321
Size Matters
Longhorn321's Avatar
Is the fluid level OK?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 04-30-2009, 07:42 AM   #4
dammitmitchell
the pollock
yes fuid is good.
and there's no "whine" when i steer... it just feels "jumpy" perfectly smooth then jumpy again.
Army vet 02-08
Old 04-30-2009, 09:31 AM   #5
bowtier
Nobody rides free
bowtier's Avatar
Maybe a tooth broken on your steer gear?
Or a whooped rag joint that's got slop & binds up?
Those are just my 2 best guesses, I have no idea.
'71 C10 LWB 400SB/350TH
'86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck
'06 HHR - wifes wheels
'01 Blazer - daily driver
"It's better to burn out than it is to rust."
-Neil Young
bowtier is offline   Reply With Quote
Old 04-30-2009, 09:50 AM   #6
Longhorn321
Size Matters
How 'bout belt tension? Also what were you doing last weekend that might have damaged the PS? If you were "4 wheelin" you may have bent some suspension components that might make it feel funny.
...WOOOO HOOOO!!!!
Old 04-30-2009, 11:50 AM   #7
Burt4x4
Burt4x4's Avatar
Could be a belt slipping, check for very shinny underside of the belt. If it is super shinny I would buy a new belt.
.02c
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-30-2009, 12:07 PM   #8
estig70
estig70's Avatar
check ball joints, especially for grease.
Eric
estig70 is offline   Reply With Quote
Old 04-30-2009, 12:48 PM   #9
dammitmitchell
the pollock
whooped rag joint????
Army vet 02-08
Old 04-30-2009, 12:54 PM   #10
bowtier
Nobody rides free
bowtier's Avatar
it's the weird looking 'joint' in your steering shaft...don't know how to describe it, looks like a disk in the shaft. 'whooped' as in not completely busted, but having play in it.
pic in this post is a rag joint
http://67-72chevytrucks.com/vboard/s...d.php?t=244273
and another rag joint thread
http://67-72chevytrucks.com/vboard/s....php?p=3226408
-Neil Young
Old 04-30-2009, 08:33 PM   #11
dammitmitchell
the pollock
ok yall
doublechecked the fluid level
and re tightened the belt ( how it squeals when i do this)
then i bring the steering more than 1/3 out to the left (from center)
or to the right (from center)
the pump does the same crap still
soooo!
i got under the hood and moved the shaft by hand to make the tires go left and right and watched the pump pulley slow down...
BUT
it only does it at that one moment.. after that 1/3 either direction from center it hitches and then works fine.....
is my ps pump wearing out?
OR should i pull off the steering stabalizers to see if it still does it
Army vet 02-08
Old 05-06-2009, 09:04 PM   #12
dammitmitchell
the pollock
ok still squealing, and i feel not so good about my truck today..
it is doin still as the described above, have friend turn wheel and you can see the pump wheel slow dramatically ( i painted a small white line so i could have a visualization for wheel speed)
what should i do?
i was thinking about opening the lines.. draining the fluids out.. and checking every thing out basically
any input or ideas?
Army vet 02-08
Old 05-08-2009, 06:25 PM   #13
Hutch
Hutch's Avatar
dammitmitchell
If you decide that you need to get your box repaired
http://www.powersteering.com/
I met them at a local swap meet several years back
They seem to specialize in pumps and know them very well.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 05-08-2009, 06:47 PM   #14
LONGHAIR
If the pump "slows" but the rest of the engine does not.....the belt is still slipping, whether it makes any noise or not.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
