Old 04-30-2009, 12:30 AM   #1
Rogue_Sentinel
Rogue_Sentinel's Avatar
if i upgrade my Intake Manifold ?
what more do i have to upgrade or buy ,so it works right ? iam looking at the Intake Manifold Torker II, Edelbrock from summit . i have a 79 scottsdale 350
http://store.summitracing.com/partde...=1#Application
"Myths and legends die hard in America. We love them for the extra dimension they provide, the illusion of near-infinite possibility to erase the narrow confines of most men's reality. Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final."
Hunter S THompson
Rogue_Sentinel is offline   Reply With Quote
Old 04-30-2009, 12:33 AM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: if i upgrade my Intake Manifold ?
new gaskets and hardware
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-30-2009, 12:44 AM   #3
Rogue_Sentinel
hardware ? bolts
i think i need new gaskets now so that why i ask about the intake upgrade.
Thanks flamingbig10
for all your help and info
Hunter S THompson
Old 04-30-2009, 01:26 AM   #4
xbanone
xbanone's Avatar
I don't know what your building but that is a single plane intake that performs in the 2500-6500 RPM range. That would be great for a serious drag car with low gears but all wrong for a street truck that needs low RPM torque.
What are you building? What are your needs?
xbanone is offline   Reply With Quote
Old 04-30-2009, 01:26 AM   #5
78 Chevyrado
Are you putting that intake on a stock motor? If you're putting it on a stock motor it will be a dog below about 3500 RPMs.
As far as the changeover, you'll need the manifold that fits your carb, or get an adapter. Otherwise it'll be just unbolt and change everything over and of coarse new gaskets for whatever you take apart. If you have the stock 4bbl carb you need an intake for a spreadbore carb. if it's an edelbrock or a holley (95% of them) you want a squarebore intake.
78 Chevyrado is offline   Reply With Quote
Old 04-30-2009, 01:34 AM   #6
flamingbig10
6.0 powered square
didn't look at the specs I would go with this one
http://store.summitracing.com/partde...1&autoview=sku
Aaron
Old 04-30-2009, 09:36 AM   #7
dammitmitchell
the pollock
dammitmitchell's Avatar
dotn forget the gasket maker that goes onto theintake bolts...
otherwise you'll leak oil out the top of your motor
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 04-30-2009, 10:37 AM   #8
Red_69
Red_69's Avatar
What he said. I had one one an '81 Camaro. Total dog down low.
1986 Chevy 3/4 Ton 4X4
Red_69 is offline   Reply With Quote
Old 04-30-2009, 11:11 AM   #9
Desert1957
Desert1957's Avatar
Yes , I think the "Edelbrock Performer" is an awesome choice for any street driven truck , Idle to 4500 RPM for torque. had3 different SBC's with them , worked Great , awesome for towing too...
Don't forget about Carb base gasket , thermostat gasket , silcone the ends of the block and don't use the end gaskets they give you..
Desert
Desert1957 is offline   Reply With Quote
Old 04-30-2009, 01:52 PM   #10
85Bowtie
85Bowtie's Avatar
If your using that intake, you might as well get the cam to match it.
Something in the 274 duration or bigger, but then youll need a set of gears, stall converter etc. and it will just keep escalating.
For your intake bolts, just use the white pipe/thread sealant, it's like teflon tape in liquid state.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
